20 Most Recent Magellan Maestro 4040 GPS Receiver Questions & Answers
2answers
Are there any free updates for a magellan gps 4040
  • The only free update for your 4040 is the latest firmware or you can call the tech support of Magellan and ask if you can still avail the latest maps for your 4040 don't forget the recepit when you call them, they may ask you to send it to them for verification.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
9/24/2020 9:42:28 AM • Magellan Maestro... • Answered on Sep 24, 2020
Dead pixels
For $75.00 I'll tell you how I fixed it!!
6/11/2017 1:49:59 AM • Magellan Maestro... • Answered on Jun 11, 2017
2answers
When using my devise it wont always respond
Are you getting error messages? Is the device being blocked by structures or landscape? Try it out in the wide open spaces.
1/22/2015 9:54:21 PM • Magellan Maestro... • Answered on Jan 22, 2015
When i plug my gps into car usb it says follow pc application. what does that mean?
Plug it into your computer with the usb to Magellan cord to see if it has what it says it needs.
9/19/2014 11:36:09 PM • Magellan Maestro... • Answered on Sep 19, 2014
How do you do a factory reset
there is a small hole big enough to put a pen tip into, press this for about 10 seconds and then power up.....will be factory reset.
8/25/2014 9:47:29 PM • Magellan Maestro... • Answered on Aug 25, 2014
Return when still under warranty
maroc casabanca derb elkabir
10/19/2013 3:28:34 PM • Magellan Maestro... • Answered on Oct 19, 2013
2answers
GPS receiver of Magellan maestro don't hold the charge
you should charge it and then when youre done dont forget to turn it off if that dont work then got to radioshack and buy a new battery!
10/19/2013 3:27:47 PM • Magellan Maestro... • Answered on Oct 19, 2013
2answers
Map update error problem with Magellan 4250
I had the same problem until I plugged the usb cable into the back port of my computer. Then it worked. Something about using a higher speed usb port.
8/1/2013 8:27:28 PM • Magellan Maestro... • Answered on Aug 01, 2013
2answers
Voice commands are garbled to the point I cannot
most likely the speaker is blown internally! Try with a headphone and see if that fixes your problem. If it does you can buy a cheap external speaker for any headphone style jack to use!
10/24/2012 12:15:05 AM • Magellan Maestro... • Answered on Oct 24, 2012
How can I get the voice to work again. No sound at all.
Google for the owner manual with the model number to make sure sound not turned to OFF, short of that maybe a bad speaker or something like that.Majellan has a fairly good customer service record and may if it needs repair fix it for a flat fee.
8/29/2012 4:53:42 PM • Magellan Maestro... • Answered on Aug 29, 2012
2answers
Port for car charger broken
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
1/20/2012 2:21:13 AM • Magellan Maestro... • Answered on Jan 20, 2012
Magellan Maestro 4040 GPS Receiver Logo
Popular Tags
318 questions posted
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
View Most Popular
Maestro Magellan
  • Maestro Magellan
Most Popular Question
magellan maestro 4040 just put firmware
  • GPS
