20 Most Recent Whirlpool 24 in. GU980SCG Built-in Dishwasher Questions & Answers
3answers
FILM ON GLASSES, IS THIS HARD WATER, MIGHT BE MY
Film on the glasses may be a sign that the softener is not working correctly. It may sound silly but check the obvious first, is there salt in the softener brine tank? if not fill it up, allow it to sit for at least 8 hours then manually regenerate the unit. Also check the power to the softener. Check to make sure the bypass is not open. If this stuff is ok then have a local reputable water treatment company come out and test the water hardness to make sure the softener is working correctly. If they say it is not working check the brine draw tubing. The most common failure is from a slight leak in the brine draw tubing which keeps the unit from regenerating effectively. During the brine draw phase of regeneration (2nd step) the softener should draw all the water from the brine tank. Repair or replace the tubing as needed.
7/17/2017 1:53:28 PM • Whirlpool 24 in.... • Answered on Jul 17, 2017
0answers
Whirlpool Gold Quiet Partner
Dlc737, We apologize for your concerns with your Dishwasher. If you have tried to reset from the breaker and it has not fixed the problem then we would recommend scheduling service. We would be happy to assist you further. Can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected]?We would be happy to assist you further.
6/16/2017 3:07:10 PM • Whirlpool 24 in.... • Answered on Jun 16, 2017
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
4/25/2017 4:23:11 PM • Whirlpool 24 in.... • Answered on Apr 25, 2017
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
11/5/2015 2:00:05 AM • Whirlpool 24 in.... • Answered on Nov 05, 2015
2answers
What are the Dimensions
24" ????
12/17/2014 6:03:11 PM • Whirlpool 24 in.... • Answered on Dec 17, 2014
0answers
980 series
Hello. Take a measuring tape and measure. Easy,nice and clean also Good luck
7/3/2013 1:07:15 AM • Whirlpool 24 in.... • Answered on Jul 03, 2013
0answers
Dishwasher makes grinding sound during wash
This means that some debris is trapped inside the motor. You can complete this repair yourself, it's simple. Remove the lower spray arm followed by the screws on the top of the motor housing.
The impeller will be below the part that lifts off with the screws removed.
Appliance & Refrigerator Parts
3/23/2011 6:51:57 PM • Whirlpool 24 in.... • Answered on Mar 23, 2011
DISHWASHER IS RUNNING BUT NOT FILLING UP WITH WATER
Your problem is probably the water fill valve is defective or it may be the drain valve is stuck open. If it is not filling with water at all, it is probably the fill valve. If it is filling as fast as it is draining, it is probably the drain valve.
If you need more help, post another comment.
Thanks,
Tim
2/7/2011 7:19:16 PM • Whirlpool 24 in.... • Answered on Feb 07, 2011
Dishes on the top rack not getting clean
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
2/6/2011 3:18:25 AM • Whirlpool 24 in.... • Answered on Feb 06, 2011
0answers
Whirlpool 24 in. GU980SCG Built-in Dishwasher Logo
76 questions posted
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
dishes not washing very
  • Dishwashers
