20 Most Recent
Enhance Technology ATX-1123B, Enhance Power Supply 230W ATX PS2 Power Supply (ATX1123B) Power Supply Questions & Answers
How to increase power on my daystate mk3
Basic power supplies should be 400 to 1000 Watts for current systems. A 230W supply is Underpowered and may not support the hardware devices all that well. In addition, the Video drains power, so a Video card with 2G Ram will help speed up the process. Then an additional Power RAM (Memory) with speed available to your system; helps increase activity. Cooling Fans help reduce HEAT that also slow down operations. Clean the inside of the computer as dirt., dust and dust balls collect and keep the electronics hot.
1/7/2014 8:18:58 PM •
Enhance...
Answered
on Jan 07, 2014
ATX motherboard connector pin out
Black=0V(GND)Yellow=12VRed=5VOrange=3.3VPurple=5Vsb(everytime on)Gray is PWRGOOD or PWROK(pwr=power) must be at 5vWhite=-5V(optional)Blue=-12VGreen is PWRon must be connected to a black wire to turn on the PSU
11/22/2012 4:31:44 PM •
Enhance...
Answered
on Nov 22, 2012
There is no power switch
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to
this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
3/1/2011 11:44:23 PM •
Enhance...
Answered
on Mar 01, 2011
Why shud i use a 230W supply on om my XBOX 360?
The more amperage you have on the 12 volt rails the more power you can draw from the power supply. For an xbox 360 I don't see any reason why you would use a non-standard power supply unit there really is no gain using a computer PSU on an xbox 360 unless you broke your factory PSU and then you could rig a computer PSU to it but your better off not trying unless your really good at electronics.
5/8/2010 7:03:10 PM •
Enhance...
Answered
on May 08, 2010
No output
Please change or replace your PS system.
2/10/2010 8:35:47 AM •
Enhance...
Answered
on Feb 10, 2010
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
