20 Most Recent Kolpak (SK8-1328-CI) Commercial Refrigerator Questions & Answers
For days now I have
if you found smell [ which cant be smelled online ] clean source so it doesnt smell any more and then no headaches and as to toxic that is also unknown
6/8/2017 8:48:02 PM • Kolpak... • Answered on Jun 08, 2017
3answers
Chemical smell from refridgerator
hello
3/14/2013 3:32:49 PM • Kolpak... • Answered on Mar 14, 2013
My Kolpak walk in cooler, it's too hot the compressor starts but after few second goes off.
Question edited for clarity. you need a service call straight away. You probably need gas, or it might be an issue with the start capacitor, or if overheating the Clixon protection device. Turn it off to protect the compressor from damage. My advice, pay for an annual service contract that includes 2 x 6 month services and 24 hour call out, parts only, labour and call out is included. That saved me many times with a walk in freezer in my own business and also with walk in fridges here in Canada.
2/26/2022 2:43:21 PM • Kolpak... • Answered on Feb 26, 2022
2answers
Kolpak walk in freezer . the door heater will not work
Suggest replace the element. Since this is an electrical/safety issue also suggest have qualified personnel attend to it.
11/2/2017 7:29:52 PM • Kolpak... • Answered on Nov 02, 2017
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
4/16/2024 12:09:58 PM • Refrigerators • Answered 5 hours ago
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage. This refers to water, not juices.
4/15/2024 9:35:54 AM • Refrigerators • Answered Yesterday
I have a 1984 Norcold 8310 series RV refrigerator that isn't working. How can I troubleshoot it?
Question edited for clarity. Help and videos in the link. However it is 40 years old and has probably seen better days. There isn't much you can do if it needs refrigerant gas as you need a certified engineer. https://www.google.com/search?q=1984+Norcold+8310+series+RV+refrigerator+that+isn%27t+working ..
4/13/2024 5:04:34 AM • Refrigerators • Answered 3 days ago
3answers
Is it normal that the compressor is too hot too touch?
yes it is
4/9/2024 3:41:40 AM • Refrigerators • Answered on Apr 09, 2024
Question mark flashing next to temperature numbers
All questions need 'make model (what it is) first 3 words please. https://www.google.com/search?q=Refrigerator+Question+mark+flashing+next+to+temperature+numbers ..
4/6/2024 11:28:44 PM • Refrigerators • Answered on Apr 06, 2024
2answers
Freezer is over freezing resulting in the the fridge not cooling. model of fridge RS22DCMS water dispensing upright fridge freezer
Sometimes the timer jmalfunctions and the refrigerator will not go in to a defrost mode. Try unplugging it and defrost the refrig and plug it in again.
4/5/2024 9:37:23 AM • Refrigerators • Answered on Apr 05, 2024
2answers
Uline beverage fridge loose door handle.
Hi
You are right. The only way to repair this is by replacing the complete door assembly. If under a year it should be covered.
3/25/2024 5:55:15 PM • Refrigerators • Answered on Mar 25, 2024
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
  1. Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
  2. Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
  3. Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
  4. Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
3/21/2024 2:20:27 PM • Refrigerators • Answered on Mar 21, 2024
2answers
Artic Air Commercial Freezer keeps freezing up. the drain tube, around the fan. It is only a few years old.
This is your freezer. https://www.google.com/search?q=Artic+Air+Model+AF49EX My advice is to check the defrost heater for efficiency and also for correct placement. You could also add an additional heater rod or heater blanket to the place where is freezes up. https://www.google.com/search?q=Artic+Air+Model+AF49EX+defrost+heater ..
3/17/2024 4:41:14 AM • Refrigerators • Answered on Mar 17, 2024
When I OPEN the refrigerator door, it starts cooling the freezer and refrigerator. When I CLOSE the door, it stops. How can this happen??
When you open the door, all the cold air tumbles out, so the fridge starts up to replace the cold air. As you close the door it is running, but you can't hear it. One it gets to temperature, it stops. It can sometimes do this is seconds. If it was truly stopped, everything would be defrosted in the freezer and everything in the fridge would be warm. ...
3/11/2024 3:07:29 AM • Refrigerators • Answered on Mar 11, 2024
Kolpak (SK8-1328-CI) Commercial Refrigerator Logo
7 questions posted
Top Kolpak Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Kolpak Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kolpak Refrigerators
Most Popular Question
days now
  • Refrigerators
