20 Most Recent Skech Custom Jacket Flip Leather Case For Iphone3 - 1 Pack - Retail Questions & Answers
Jailbreak iphone3
Google "RedSn0w" for details and instructions there is a group called dev team that can help you
10/25/2012 8:48:28 PM • Skech Custom... • Answered on Oct 25, 2012
There seem to be two categories of notes on my iPad Pro. One is Notes which is going to iCloud and the other is ATT notes which is not syncing with my other devices and not going to iCloud.
It sounds like you have notes saved in two different locations on your iPad Pro. The "Notes" app likely syncs with iCloud, meaning your notes are accessible across your Apple devices linked to the same iCloud account. On the other hand, "ATT notes" may be a separate app or service that isn't integrated with iCloud, resulting in notes that are only stored locally on your iPad Pro and not synced with your other devices. To ensure all your notes are synced across your devices, you might want to consider migrating your notes from the "ATT notes" app to the standard "Notes" app that syncs with iCloud. This way, you'll have access to your notes from any device connected to your iCloud account. If you're unsure how to do this or need further assistance, feel free to ask!
4/16/2024 5:23:44 AM • Cell Phones • Answered 8 hours ago
Fccidalsmt877t it wont charge how do i fix this
If your device with the FCC ID AL5MT877T (which corresponds to the Samsung SGH-T877T, also known as the Samsung Galaxy Note 10.1) is not charging, there are a few steps you can take to troubleshoot and potentially fix the issue: 1. **Check the Charger and Cable**: Sometimes, the issue is with the charger or the charging cable. Try using a different charger and cable to see if the device charges properly. Make sure the charger and cable are compatible with your device. 2. **Clean the Charging Port**: Dust, lint, or debris may accumulate in the charging port over time, preventing a proper connection with the charging cable. Use a small brush, compressed air, or a toothpick to carefully clean the charging port. 3. **Restart the Device**: Sometimes, a simple restart can resolve temporary software glitches that may be preventing the device from charging. Turn off the device, wait a few seconds, and then turn it back on. 4. **Check for Software Updates**: Ensure that your device's software is up to date. Go to Settings > About device > Software update (or a similar menu option) to check for and install any available updates. 5. **Perform a Soft Reset**: A soft reset can sometimes help resolve charging issues. Press and hold the power button and the volume down button simultaneously for about 10 seconds until the device restarts. 6. **Check for Physical Damage**: Inspect the charging port and the charging cable for any signs of physical damage. Bent pins or frayed cables can prevent the device from charging properly. 7. **Try Charging from Different Power Sources**: Plug the device into different power sources, such as a wall outlet, a USB port on a computer, or a different power adapter, to see if the issue persists. 8. **Check Battery Health**: If the device still doesn't charge after trying the above steps, there may be an issue with the battery itself. Consider taking the device to a certified repair center or contacting the manufacturer for further assistance. If none of the above steps resolve the charging issue, it's possible that there may be a hardware problem with the device that requires professional repair. In that case, it's best to seek assistance from a qualified technician or the manufacturer's customer support.
4/16/2024 5:22:19 AM • Cell Phones • Answered 8 hours ago
I forgot my parent access code, my daughter's phone is locked.
If you've forgotten the parent access code for the HiSense F22 phone, you'll likely need to perform a factory reset to regain access to the device. However, please note that a factory reset will erase all data on the phone, including apps, photos, and settings. Here's how you can perform a factory reset on the HiSense F22: 1. **Power Off the Phone**: If the phone is turned on, power it off by pressing and holding the power button until the power menu appears, then select "Power off" or "Restart" and confirm. 2. **Boot into Recovery Mode**: Press and hold the Volume Up button and the Power button simultaneously until the HiSense logo appears on the screen. Release both buttons. 3. **Navigate Recovery Menu**: Use the Volume Up and Volume Down buttons to navigate through the recovery menu options. Look for an option that says "Wipe data/factory reset" or similar. 4. **Select Factory Reset**: Once you've highlighted the "Wipe data/factory reset" option, press the Power button to select it. 5. **Confirm Factory Reset**: You'll be prompted to confirm the factory reset action. Use the Volume buttons to highlight "Yes" and press the Power button to confirm. 6. **Perform Factory Reset**: The factory reset process will begin, and the phone will erase all data and reset to its factory default settings. This may take a few minutes. 7. **Reboot Phone**: Once the factory reset is complete, the recovery menu will appear again. Select the option to reboot the phone system now. 8. **Set Up the Phone**: The HiSense F22 will reboot and start up as if it were brand new. Follow the on-screen instructions to set up the phone, including language, Wi-Fi, Google account, etc. After completing these steps, your HiSense F22 phone should be unlocked, and you'll have access to it without the parent access code. Remember to set a new parent access code or passcode to prevent unauthorized access in the future.
4/16/2024 5:20:03 AM • Cell Phones • Answered 8 hours ago
I'm trying call and the only find are not in service where can i get a good phone#
Finding a good phone number to contact can depend on what you need assistance with. Here are some general tips for finding reliable phone numbers: 1. **Official Websites**: For businesses, organizations, or government agencies, visit their official websites. They often provide contact information, including phone numbers, for customer service, support, or inquiries. 2. **Customer Support**: If you're trying to reach a specific company or service provider, look for their customer support phone number. This information is usually available on their website, in the "Contact Us" section or the footer of the page. 3. **Directories**: Online directories like Yellow Pages or White Pages can sometimes provide phone numbers for businesses or individuals. You can search by name, category, or location to find contact information. 4. **Social Media**: Some businesses provide customer support through social media platforms like Twitter or Facebook. You may be able to find a phone number or get assistance through direct messaging on these platforms. 5. **Reviews and Recommendations**: Check online reviews or ask for recommendations from friends, family, or online communities. They may be able to suggest reliable businesses or services with good customer support. 6. **Local Resources**: For local businesses or services, you can check local directories, newspapers, or community websites for contact information. 7. **Google Search**: Sometimes a simple Google search with the company name followed by "phone number" can yield results. Be cautious and verify the legitimacy of the phone number before calling. 8. **Official Documentation**: If you're trying to contact a government agency or institution, official documents or correspondence from them may include contact information. Remember to exercise caution when providing personal information over the phone and verify the legitimacy of the phone number and organization you're contacting, especially if you found the number through unofficial channels.
4/16/2024 5:18:03 AM • Cell Phones • Answered 8 hours ago
Need the reset code for cashpower 2000 prepaid electricity meter
To reset a Cashpower 2000 prepaid electricity meter, you typically need to follow a specific procedure provided by the manufacturer or your electricity service provider. Unfortunately, there isn't a universal reset code that applies to all Cashpower 2000 meters, as the process may vary depending on the meter model and configuration. Here are some general steps you can try to reset your Cashpower 2000 prepaid electricity meter: 1. **Contact Your Electricity Provider**: The best course of action is to contact your electricity service provider or utility company directly. They should be able to provide you with the necessary instructions or assistance to reset your meter. 2. **Check the Meter Manual**: If you have the manual for your Cashpower 2000 meter, refer to the troubleshooting section or search for instructions on how to reset the meter. The manual may contain specific steps or codes required for the reset process. 3. **Enter Maintenance Mode (If Applicable)**: Some meters have a maintenance mode or access code that allows users or technicians to perform resets and other functions. Refer to the manual or contact your provider to inquire about accessing maintenance mode, if applicable. 4. **Power Cycle the Meter**: In some cases, simply power cycling the meter by turning it off and then back on again may help resolve certain issues. However, be cautious when doing this, as abruptly cutting power to the meter may disrupt its operation or cause errors. 5. **Seek Professional Assistance**: If you're unable to reset the meter using the available resources or instructions, consider seeking assistance from a qualified technician or electrician. They may have the expertise and tools necessary to perform a reset or diagnose any underlying issues with the meter. It's important to note that attempting to reset the meter without proper guidance or authorization may result in unintended consequences or even damage to the meter. Always follow the instructions provided by your electricity provider or consult with a professional if you're unsure about how to proceed.
4/16/2024 5:11:58 AM • Cell Phones • Answered 8 hours ago
2answers
Kyocera DIGNO Dual WX04K. HOW TO RESET KYOCERA WX04K DUAL DIGNO please?
How to hard reset KYOCERA DIGNO WX04K WILLCOM
GSM Hosting https://forum.gsmhosting.com > vbb > how-hard-reset... Feb 24, 2016 - Ihave solution turn off mobile than holde both volume keys and connect usb i will install adb drivers and than install kingoroot in pc and ... Missing: DUAL ‎' Show results with: DUAL
How To Do A Hard Reset On Kyocera DIGNO Dual WX04K
Tweakdroid https://tweakdroid.com > hard-reset > kyocera-digno-d... Nov 28, 2021 - To start, go to the Settings menu of your Kyocera DIGNO Dual WX04K; Find the factory data reset option. · Click on Erase all data. ; Turn off the ... ..
4/16/2024 5:10:45 AM • Cell Phones • Answered 8 hours ago
Where can I get a new sim card tf64simt5v2
The "TF64SIMT5V2" appears to be a specific model or type of SIM card. While I don't have access to specific inventory or suppliers, you can typically obtain a new SIM card from the following sources: 1. **Mobile Network Provider**: If you're using the SIM card for a mobile phone plan, your mobile network provider (e.g., Verizon, AT&T, T-Mobile, etc.) will provide you with a compatible SIM card. You can visit their retail stores, contact customer service, or order one online through their website. 2. **Electronics Retailers**: Many electronics retailers, both online and brick-and-mortar stores, sell SIM cards. You can check stores like Best Buy, Walmart, Target, or electronics sections of department stores. 3. **Online Retailers**: Online marketplaces like Amazon, eBay, or specialized electronics retailers often carry a variety of SIM cards, including specific models or types like the TF64SIMT5V2. Be sure to verify compatibility before purchasing. 4. **Specialty Stores**: Some specialty stores or mobile phone accessory shops may carry SIM cards. These stores often cater to specific mobile phone brands or models and may have a selection of SIM cards available. 5. **Manufacturer or Distributor**: If the SIM card is associated with a specific device or manufacturer, you may be able to obtain a replacement directly from the manufacturer or an authorized distributor. When purchasing a new SIM card, make sure it's compatible with your device and mobile network provider. If you're unsure about compatibility or have any specific requirements, it's a good idea to contact your mobile network provider or the manufacturer of your device for guidance.
4/16/2024 5:09:46 AM • Cell Phones • Answered 8 hours ago
Troubleshooting stanley bs16bs
If your Stanley BS16BS battery charger is consistently displaying "FLO" regardless of the battery's charge level or condition, it typically indicates a fault with the charger or an incorrect connection. Here are some troubleshooting steps you can try to resolve the issue:
  1. Check Battery Compatibility: Ensure that the Stanley BS16BS charger is compatible with the type of batteries you are trying to charge. The charger may not be suitable for certain battery types or sizes.
  2. Inspect Battery Connections: Make sure the battery is properly connected to the charger. Check for any loose connections, corrosion on the terminals, or damaged cables. Clean the battery terminals and charger clamps if necessary.
  3. Verify Charger Settings: Double-check the charger settings to ensure they are appropriate for the type of battery you are charging. Some chargers have adjustable settings for different battery types and sizes.
  4. Test with Different Batteries: Try charging a different battery with the charger to see if the issue persists. If the charger displays "FLO" for all batteries, there may be a problem with the charger itself.
  5. Reset or Restart: Turn off the charger, unplug it from the power source, and wait for a few minutes. Then, plug it back in and restart the charging process. This can sometimes reset the charger and resolve minor issues.
  6. Check for Overheating: If the charger feels excessively hot during use, it may be overheating and shutting down as a safety precaution. Allow the charger to cool down before attempting to use it again.
  7. Inspect for Damage: Inspect the charger for any visible signs of damage, such as frayed wires, burnt components, or melted plastic. If you notice any damage, discontinue use of the charger and have it inspected by a qualified technician.
  8. Contact Manufacturer Support: If none of the above steps resolve the issue, contact Stanley or the manufacturer's customer support for further assistance. They may provide additional troubleshooting steps or advise you on warranty coverage or repair options.
By following these troubleshooting steps, you should be able to identify and resolve the issue with your Stanley BS16BS battery charger displaying "FLO."
4/16/2024 5:08:14 AM • Cell Phones • Answered 8 hours ago
How do I fix E71 on the la cimbal Q1?
You posted to the category 'Cell Phones'. This is likely a 'La Cimbali' rather an 'la cimbal' a coffee machine. This is also likely to be a Q10 rather than a Q1 which is Tamping Machine from Puq. All questions need full 'make model (what it is)' first 3 words please. Upper right of this page in the manual https://www.manualslib.com/manual/1737003/Lacimbali-Q10-New-Touch.html?page=32#manual No other clues except that Cimbali does an E71 model in Dubai. https://www.google.com/search?q=la+cimbali+e71+error ..
4/13/2024 11:15:32 PM • Cell Phones • Answered 2 days ago
2answers
I need a PUK code for total station leica TS06.
I need leca t.s 06 plus serial 1891880 puk cod
4/13/2024 2:47:17 PM • Cell Phones • Answered 2 days ago
Mine got good volume but when they talk you can barely hear them
'Make model (what it is)' in all question please first 3 words. You posted to the category 'Cell Phones' so let's assume it is a phone. When you are actually in a call use the buttons on the side of the phone to increase the volume. It is usually the upper button, and can only be done when you are on a call.
9 Ways to Improve Your Android Phone's Sound and Volume
Lifewire https://www.lifewire.com > Mobile Phones > Android Jul 12, 2023 - To make sure the volume on your phone is working properly: Turn off Do Not Disturb Mode. Along with silencing your ringer, Do Not Disturb mode ... ..
4/9/2024 4:11:16 AM • Cell Phones • Answered on Apr 09, 2024
GPX Media Player model MT851B. My touchscreen doesn't respond on it. How do I fix it
There doesn't seem to be anything online to suggest how to do a reset or recalibrate the screen. You could try three things Look for a tiny Reset hole in the back. Connect it to a computer and in Windows Explorer see if the is any useful right click commands? Or leave it running until it runs out of power, wait 24 hours before recharging. ..
4/9/2024 3:30:50 AM • Cell Phones • Answered on Apr 09, 2024
What does it mean for actaris prepaid meter to write ""call" on standby screen. Is it spoilt?. Quick response pls. Thanks.
I would call your service provider as I think that is what it means. There is no error message "call", as far as I can find.
4/8/2024 5:13:35 PM • Cell Phones • Answered on Apr 08, 2024
I did not write down my password for my bluetooth 3.0 key board
There is usually a feature with bluetooth devices where you can force them to reconnect to your computer. Go into the computer settings and 'forget' this device. Then force the keyboard to re-pair with the computer. This should do the trick!
4/8/2024 2:37:23 PM • Cell Phones • Answered on Apr 08, 2024
Track my phone thats is off
This can't be done. If the phone is powered off or the battery dies, the GPS isn't working and it can't be tracked. If you go into 'Find my Phone' you can see the last position it was located, but you won't be able to get a current position if the power is off or dead.
4/8/2024 2:35:20 PM • Cell Phones • Answered on Apr 08, 2024
I bought my Mom a Flip phone and she has Straight Talk service. The phone will not ring when someone calls in. HELP!
I would check 2 things. First, make sure the phone doesn't have a 'sound off' button on it. Many phones have a button on the outside that turns off any rings, beeps, etc. Make sure if that exists that its not turned on. If you either don't find one or its not engaged, then I would call Straight talk and have them ensure that the cell service is properly 'provisioned' for your Mom's phone. Sometimes the cell companies screw up and the phone won't ring. Either of those will hopefully do the trick!
4/8/2024 2:33:38 PM • Cell Phones • Answered on Apr 08, 2024
How doe i connect coolpad model # 5560s to the internt
Connecting a CoolPad 5560 to the internet ... you need to connect your machine to your router either wirelessly, (follow the router instructions) or wired with an RJ45 cable. If wireless look for the router, type in the routers password and save it. That is it you will be on the internet, if the router is connected to your internet. Likewise for hard wiring (and you won't need the password).
4/7/2024 5:50:37 PM • Cell Phones • Answered on Apr 07, 2024
The key crack is not working
Possibly a generic code that now no longer works as each code can only be used on one machine.
4/7/2024 5:14:22 PM • Cell Phones • Answered on Apr 07, 2024
Skech Custom Jacket Flip Leather Case For Iphone3 - 1 Pack - Retail Logo
1 questions posted
Popular Products
Top Skech Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Skech Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Skech Cell Phones
  • Skech Cell Phones
Most Popular Question
jailbreak iphone3
  • Cell Phones
