20 Most Recent
Samsung Gt-s3350 Chat Unlocked Phone - Us - Black Questions & Answers
Samsung s3350 forgotten phone lock password
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Reset factory samsung GT-s3350
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
How to unlock samsung gt-s3350 for invalid sim problem
My Dear brother:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Samsung gt_s3353 sim lock problim
Please be advised that only your Service provider can provide you the code to unlocked the sim lock on your phone.
- Thank you,
Hi i forgot my phone lock password how do i bypass or remove it
I had a look through some forums and the best answer I found was this:
Try the last 4 digits of your phone number. If you can't remember the number, then the only solution I know of is to remove the SIM card from the phone (if you have one) and enter the number below. This will erase everything on the phone that is not saved to a memory card (if you have one) or to the SIM card.
*2767*3855#
If that doesn’t work, try:
*0206*3855#
As i said i found this on a forum and the replies to it where positive but maybe do a lil' research into it yourself before you try it.
Hope this helps :)
How do I take off predictive text ?
Download the user guide from here:-http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1903&prd_mdl_cd=GT-S3350HKAVOP&prd_mdl_name=GT-S3350&srchword=GT-S3350
