20 Most Recent
LG GSA-H22N DVD±RW Dual Layer Burner Questions & Answers
I want to burn a karaeoke disc
The problem isn't the burner. You need karaoke software to burn and view cdg files. Below is a link to free karaoke software. Install the software (or a software package of your choosing) and re-burn your files.
Karaoke Builder
Whenever i insert a dual
Hi sadh_priyank
Check this in the following order :
You are using a program set to 4.5 GB or your device is set to 4.5 GB or you are using an unappropriate disc .
Best regards ,
fanaudi .
Burn Completed Successfully" but files not shown
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions or just replace them there probably bad/faulty
hope this helps
The dvd door fail to open
To open this drive you can open My Computer and right click your DVD drive and select eject. You can also open any CD/DVD drive by taking a paper clip (or something the size of one) and inserting it inside the tiny pinhole near the eject button on the drive.
DVD burner will not recognize blank DVD's now
Did you try using Nero or Roxio? Don't only rely on the standard Windows support for CD/DVD writing.
Did you connect the new hdd the same way as the old hdd, or did you add it to the same cable as the CD/DVD writer perhaps? If multiple IDE devices are on the same cable, the master slave setting can cause problems. If you are using SATA devices, that should not be a problem.
Drivers are not required for IDE devices, including most CD/DVD writers, so don't bother with that.
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Dvd burner no worky.
Disconnect completely your driver and do the connection again from stratch! May work ! REG clean and Verify Disc before reinstalling! Good luck!
DVD region
You miss-understood. AnyDvd copies directly from the DVD drive to the hard disk, and removes region info as it does. Then a backup DVD can be created from the image file. The image file can also be accessed by DVDShrink to alter the size to fit.
Freezing computer
Right now, your best bet is to try and remember the last time all ran well and run a system restore....accordianman
DVD WRITER NOT WORKING
It sounds like you don't have the proper driver installed for that device. Without the appropriate driver your software will not be able communicate with the device properly.
