20 Most Recent Whirlpool LGR6611L Gas Dryer Questions & Answers
You seem to be able to troubleshoot, check and see if shaft is rotating on motor sometimes the bearing fails
Whirlpool... | Answered on Jul 19, 2017
follow this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gV3bBWAa
Whirlpool... | Answered on Oct 01, 2013
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Whirlpool... | Answered on Dec 27, 2010
ok have u checked the hi and low relays for continuity these are both found aroundthat area as well and make sure you unplug yr machine before performing this test you also have an ignitor inside the unit which should be drawing 3.3 amps if it is lower then you should replace the ignitor hope this helps
Whirlpool... | Answered on Jul 18, 2010
1. Does the dryer light come on when you open the door? If so, it's likely the belt is broken. You will need to replace the belt.
2. No dryer light? it's likely then that the thermal fuse is blown. They are located in different places on different dryers. On Maytag and many Whirlpool dryers, it is located under the top, right next to the heating element with two white wires leading to it. You can test the fuse by bypassing it TEMPORARILY. If you connect the two wires together or make a jumper for them, (always shut the dryer circuit breaker off FIRST before attempting this) and the dryer magically comes alive (after you turn the circuit breaker back on) then you know what's wrong. Just changing the fuse is often not enough - you should find out why your dryer overheated. (poor airflow - blocked duct, etc)
Whirlpool... | Answered on May 27, 2010
I know it isn't much help but look for wear on the idler arm bracket, it will tell you which way it faces either up or down....then look for wear where the idler arm bracket hooks to the frame of the dryer....also you will look to where the spring attaches to the frame of the dryer when you attach it to the idler arm there will be a slight amount of wear where the spring attaches to the frame....
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Whirlpool... | Answered on Nov 12, 2009
there isn't a pilot you have an electroic ignitor in there part number 279311.there also is a sensor,gas coils and the gas valve,you need a meter to read them out,you said you checked the breaker and cleaned lint out ,is it dead?read out the thermal fuse first part number 3392519 located on blower wheel housing,unplug the dryer before you do anything and pull off one of the wires on thermal fuse then read it out hope this helps
Whirlpool... | Answered on Nov 09, 2009
have you try to rotate the drum when belt is attached or installed, unplug your machine and try to spin it manualy at the back opening where you can access the mechanical part
try to use the belt when turning it counter-clockwise see if it will turn the drum, if not then the fproblem is the bearing
SOUNDS LIKE YOU ARE RIGHT. EASIEST WAY TO TELL IS PRY UP THE TOP PANEL. 1ST REMOVE LINT FILTER AND 2 SCREWS BEHIND FILTER ON TOP PANEL.. GET A FLAT BLADE SREWDRIVER AND TOWARD THE FRONT OF THE TOP PANEL THEIR R 2 BLK CLIPS ONE ON EACH SIDE PUSH IN AND THAT SHOULD RELEASE THE CLIPS ONCE YOU GET THE TOP UP. LOOK AT DRIUM IF YOU DONT SEE A BLACK BELT GOING AROUND TUB THEN BELT IS BROKE. PART # 341241 SELLS FR ABOUT 15-28.99. WE STK IT. ITS A VERY COMMON BELT. SHOULD BE ABLE TO GET LOCALLY. IF YOU NEED IT WE HAVE THEM.
allbrandsappliancerepair.com
Whirlpool... | Answered on Sep 23, 2009
you can but now you have to turn the motor shaft at the belt end..i believe you can put your adjustable behind the plastic square blower wheel shaft..on the motor shaft and try turning with your hand its hard to turn because the drum when turning turns the oppsite way,,im,,here onthejob..use gloves
Whirlpool... | Answered on Jan 11, 2009
ok corvett your there you just jumped one step..put the motor back and put the 2 motor clips back on,,,ok,,,,now you need to hold the belt side with a tool a grip pliers,,a wrectet head with handle turn which ever tool handle so it will hit the side of the cabnit the right side looking from front,,now wedge that tool..be careful go behind ,,put on worh gloves a must the side of blower wheel housing are sharp..caution got your gloves on,,now turn it to the left not the right,,counter clock wise..onthejob
Whirlpool... | Answered on Jan 10, 2009
If it has been working and suddenly, have this problem it could very well be the child lock has been activated.
Whirlpool Dryers | Answered on Nov 10, 2019
I have added a link. It explains the 5 most common reasons a dryer won’t start.
Whirlpool Dryers | Answered on Nov 08, 2019
Your heating element is shorted to ground Replace your heating element
Whirlpool Dryers | Answered on Sep 07, 2019
How to Disable a Dryer's Buzzer
  1. Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. ...
  2. Locate the buzzer. ...
  3. Pull the buzzer's wires. ...
  4. Test the machine.
reference: https://www.hunker.com/13410550/how-to-disable-a-dryers-buzzer
Whirlpool Dryers | Answered on Aug 27, 2019
does your dryer have a dry sensor ? if so try changing the dial to a different setting that doesn't use the sensor, also some models have a separate button to turn off the dry sensor. it is meant to save energy if your clothes are dry before the time you set
Whirlpool Dryers | Answered on Aug 18, 2019
Whirlpool LGR6611L Gas Dryer Logo
13 questions posted
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
dryer drum not spin
  • Dryers
