20 Most Recent Vodafone 945 Touchscreen Wi-Fi Android Unlocked Phone Questions & Answers
Pettern unlock
To resolve such problem you can do the factory reset. Following are the steps you have to follow to do this:- 1. switch off your tab. 2. now you have to put on volume up. 3. Then press power and home button simultaneously... 4. You will enter into menu option. 5.select setting. 6. go to factory reset... After doing this if the problem is not resolved then you should contact to the service center to do this... they will unlock the pattern as well as update your tablet...ORJust guess it wrong about 5 times and click on the "I forgot my pattern unlock" and enter your Gmail information and they will send you an email with the information needed to unlock your device.
9/27/2015 8:41:51 AM • Vodafone 945... • Answered on Sep 27, 2015
How to reset my vodafone945
Ok there are two different ways to do this. You can do a factory reset or just try the pattern/password about five times and it will ask if you forgot it and you will select yes. After doing that you will enter your email information and they will give you information to unlock your device.
8/18/2013 5:41:37 PM • Vodafone 945... • Answered on Aug 18, 2013
How to make Vodafone modem universal network?
In the link probably. The question is not clear. https://www.google.com/search?q=How+to+make+Vodafone+modem+universal+network ..
2/21/2024 6:09:02 AM • Vodafone Cell... • Answered on Feb 21, 2024
How do I unlock sim network for vodafone smart n12
Contact your service provider.
7/20/2022 8:06:13 AM • Vodafone Cell... • Answered on Jul 20, 2022
How to fix network on vodafone 785?
In order to do that: 1. Go to Settings 2. Choose the option More Networks in the Connection settings. 3. Then tap on Mobile Networks 4. Find the Network mode. 5. Change the Network from 3G to 2G. A much cheaper solution is to by a 3G/GMS antenna. It is usually quite small and you can put it anywhere in the room. Remember that the higher the antenna is located, the better the signal is. If you need an antenna for a bigger building we would recommend hiring a company which specializes in that field.
7/5/2020 6:10:52 AM • Vodafone Cell... • Answered on Jul 05, 2020
I ned helpe I forgot password in my Vodafone webbox w1
Hello Daniel, you can contact and drop a mail addressed to [email protected] to solve this issue.
3/18/2020 6:06:01 PM • Vodafone Cell... • Answered on Mar 18, 2020
How to unlock vodafone ce 1588
You would have to contact an unlocking company or the carrier directly for the unlocking code. Also, browse over to Swappa and check if the phone is blacklisted or blocked on just the carrier's network. Some get blocked on ALL major networks and can only be used outside of the US.
11/25/2019 12:25:49 PM • Vodafone Cell... • Answered on Nov 25, 2019
0answers
2answers
My phone is not connecting to internet for vodAfone kicka phone
I am sharing some links which can helps you to configure internet (data & internet both) on your Kicka phone. If you like the answer please vote my answer thanks https://deviceguides.vodafone.ie/vodafone/smart-4/explore/set-up-your-phone-for-internet https://deviceguides.vodafone.ie/vodafone/smart-ii/change-settings/connect-to-wi-fi-network
3/12/2019 12:20:56 PM • Vodafone Cell... • Answered on Mar 12, 2019
2answers
HOW TO UNLOCK VODAFONE VFD 200 NETWORK
It can be unlocked with the help of CM2 SPD Module By connecting it with PC
2/22/2019 11:30:31 AM • Vodafone Cell... • Answered on Feb 22, 2019
How to open peteni for Vodafone vfd200
Google-VDF200 UNLOCK CODES
2/21/2019 7:48:15 PM • Vodafone Cell... • Answered on Feb 21, 2019
2answers
How to reset my Vodafone VF 200 Cellphone
When you are unable to power on your Vodafone Smart First 7 VFD 200 phone hard reset recovery tutorial
This is a simple step by step instructional article to help guide you through the steps of doing a hard reset on your VFD 200 Android phone.
If your phone crashes, reboots, freeze, or cannot be powered on Some third-party software is not compatible with your phone. Reset the phone to factory status. Uninstall the software that may cause the problem or upgrade the phone software.
Turn off the phone.
Press and hold the Volume DOWN and POWER ON the phone until the phone turns on, the screen lights up.
Keep holding the POWER and press shortly the Volume UP and then shortly the VOLUME DOWN.
Now the recovery menu will come up.
Use the volume key and navigate to Wipe data / Factory reset and press POWER to confirm the highlighted selection.
Navigate to yes -- delete all user data and confirm the data deletion.
Wait until the hard reset operation ends and the phone reboots.
Note: After this procedure the first boot may take a little longer than usual. Be patient.
When you first power on your phone after reset it to factory settings (in Backup & reset menu option), you need to finish some basic settings before using it.
Flick the language field to select the language. Then foll
2/9/2019 6:30:53 PM • Vodafone Cell... • Answered on Feb 09, 2019
Vodafone 945 Touchscreen Wi-Fi Android Unlocked Phone Logo
6 questions posted
Top Vodafone Cell Phones Experts
Kolbrun...
john h
 Mikey
Mikey
Are you a Vodafone Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Vodafone Cell Phones
Most Popular Question
reset vodafone945
  • Cell Phones
