20 Most Recent
Nikon N8008 AF 35mm SLR Camera Questions & Answers
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
How do you rewind film in nikon n8008s
At the end of the roll, press the film-rewind/multiple-exposure button (marked with a roll of film and "ME", at the three-o'clock position on the round pad on the left of the camera. In mid-roll, press that button and the film-rewind button just to the right of the prism simultaneously. See the illustrations on page 19 of
this manual.
I don't know how to
You're referring to the MF-21 Multi-Control back. You can download a copy of the manual from
http://butkus.org/chinon/nikon/nikon_mf-21/nikon_mf-21.htm
Just download part 1. It has the whole thing, while part 2 is just the second half.
I have a Nikon N8008.
I have 3 N8008s bodies and one of them started hanging up in the manner you describe, but only at 1/8000th sec. The reason you can't see through the viewfinder is because the mirror is up. One mine, pressing the shutter release button again brings it down. Some other solutions online suggest weak batteries, but I've ruled that out. It also seems that this is just something that can eventually happen with the N8008/N8008s. It bugs me that this started happening, but I only paid $16 for the camera and I've never, ever taken a photo at 1/8000th.
What does the shutter speed set on?
To set the shutter speed, press and hold the mode button and then turn the thumb wheel on the right until M (for fully manual control) or S (for shutter priority auto exposure) appears in the display. Remove your finger from the mode button and the thumb wheel will now adjust just the shutter speed. If you're in manual mode the aperture setting will need a separate adjustment for correct exposure, if you're in shutter priority mode the camera will select the aperture suited to your shutter speed for each exposure.
Please take a moment to rate my answer, or if you wish to know anything else please add a follow-up comment and I shall provide further assistance when I'm next online (I'm in the UK and it's just after midnight right now).
From bob
I took the top
Hi roobk53, I can solder well however, I would not do it on that camera. Here is the location for the
manual. It may provide you the information you desire.
Batterys corroded ruined holder and hold down got
Yes the cover must be on for the battery to make contact to complete the circuit. You can try getting a cover from PhotoTech Repair Service. They are Nikon Authorized repair facility and should have the part.
website is www.phototech.com
What type of lens works with this Nikon N8008s
Any of the Nikon Auto Focus(AF) lenses should work fine with it. There are also a number of fine aftermarket lenses made for your 8008, by Sigma, Tamron, Tokina, Quantaray and others. Be sure you get the Nikon AF lenses, as they make the same lenses for Sony and Canon. You cannot use the Lenses made for another brand, as they will not fit, work right, and can damage your Nikon.
I was taking some photos (I had got around taking
it seems to think you reached the end of the film. Try rewinding. Once in a great while film does not want to exit the canister for whatever reason. It stops. that creates tension, film advance motor stresses out and signals the computer program which tells you that it thinks you're outa film. REWIND!!!
I doubt you did anything wrong. Try rewinding the film. Another possible fix if its electronic issues is to remove power(battery) and reinstall battery.
lightspiritphotography.com
How do you load film into the Nikon N8008S
Open back, insert film cartridge, pull leader to red mark, close back, press shutter button.
See above URL for a downloadable manual. For the N8008s you're better off with the F-801s manual.
