Samsung Corby WiFi S3653w: How to download WhatsApp:
The short version: No. The Samsung S3653w is not a compatible Operating System with the WhatsApp software, and can not be installed.
This is a review of your phone's Operating System. It is not Android:
Samsung Corby WiFi S3653w Pink
>>> From extended research, I've noticed a lot of blog posts about upgrading the operating system to Android firmware up to Jelly Bean and the use of "upgrade to firmware" = this is a false statement and the loose term of what that is. Meaning these bloggers are misusing that term. What these really are: it is a Firmware designed to look and feel like that Android version but it is not the exact version. It is only a "theme." So, in answer to your question. No, your phone can't run WhatsApp because it is not compatible with your phone's original operating system. Your phone is a JAVA phone.
From the WhatsApp compatibility requirements the least Android version the app can run on is Android version 2.1
https://www.whatsapp.com/android
So, unfortunately you will not be able to download and install WhatsApp on your phone from the online store..
If you do get another phone that is an actual Android Smartphone or some other compatible phone/tablet and need to download the WhatsApp software, you can get it here:
WhatsApp Download
Follow the directions on your particular device to install
Step 1. Get your facts right. To find a working unlocking code for your handset, you need three pieces of info: its brand/model number, the network, and the IMEI code. ...
Step 2. Find an unlocking code. There are a raft of websites dedicated to phone unlocking. ...
Does it turns to blue screen right after you turn it on? Did you try to remove battery for a while and re-insert it back? Try to factory reset it as a last resort.
Hello My dear Friend::::::"::":"defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
First All Check:1.Confirm whether same sim card is working in other h.s or not.2.Make sure the sim slot is o.k. only try these two.3.If all the above steps fails, check the SIM card connector pins for damage.if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.u can make it jumper mean u can fix this prob with out sim card is for this contact.5.take sim connector slight up by pin then cheak by inserting sim.6.hot air gun on sim i.c. then cheak it.Last Option:IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service& Sim Office and Get the Duplicate Sim Same Your No From Office OpratorProblem will Solved Quickly
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
