20 Most Recent Acer Aspire 3690-2710 Notebook Questions & Answers
2answers
I have a SOny VAIO PCG-K35 and my battery light is
**** your **** lol :)
1/2/2014 3:31:47 AM • Acer Aspire... • Answered on Jan 02, 2014
0answers
Camera acer aspire 3690-2710
Download the WEBcam and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: - http://www.acersupport.com/drivers_download.aspx
2/25/2012 5:52:16 AM • Acer Aspire... • Answered on Feb 25, 2012
Setup password
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type
compact /U C:\bootmgr
compact /U C:\ntldr
12/24/2010 11:19:40 PM • Acer Aspire... • Answered on Dec 24, 2010
Acer orbicam 3690-2710 stop working after install.
Access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Orbicam) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
12/7/2010 9:39:47 AM • Acer Aspire... • Answered on Dec 07, 2010
Need ethernet driver for acer aspire 3690 where I
ethernet driver for acer available at this address: http://xpdrivers.com/acer/_2_135201.cfm?gclid=COTmkdbth6MCFcl25QodIl4Ncg
Just copy and paste into your browser:))))
7/25/2010 11:48:02 PM • Acer Aspire... • Answered on Jul 25, 2010
2answers
Wont accept password
Long time ago , I was confronted with the password problem. Finally , my friend Jane introduce the Windows Password Recovery Tool 3.0.It helps me access windows.
3/8/2010 10:16:27 AM • Acer Aspire... • Answered on Mar 08, 2010
2answers
How to get it to start in safe mode to do a system restore
in starting in bios screen always press f8 and select safe mode...
3/7/2010 10:01:38 AM • Acer Aspire... • Answered on Mar 07, 2010
Restarting problems
Restarting problem could be due to Over-Heating of the CPU or Virus, worm, malware infection.
For overheating problem, you need to open the notebook and blow it with an air blower mainly near the CPU area.
For virus or worm problem, you can scan the system with a good anitvirus like Kaspersky Internet security 2010 or Mcafee Internet security with their latest updates installed.
Hope it will solve your Problem.
2/26/2010 9:28:34 AM • Acer Aspire... • Answered on Feb 26, 2010
Laptop will connect to the internet through a
Go to Control panel, system icon -- then go to the device manager and look at you hardware - See if you have a yellow mark next to anything there and if you do, delete it. Now go to the small computer icon at the top - right click and chose scan for changes. See if it will now find your Lan card. If it ask for software, browse for the files you downloaded see if that will fixit up.
2/14/2010 1:40:37 AM • Acer Aspire... • Answered on Feb 14, 2010
Is it possible to upgrade the ram to 2gb when it's
Go to www.crucial.com allow them to run their checker on your machine
It will come back with the maximum amount of Ram you can fit and a price for supplying
They are a really good company to deal with
1/30/2010 3:36:43 PM • Acer Aspire... • Answered on Jan 30, 2010
My Aspire 3690-2710 is running super slow!
The simple answer is: You can't! The processor is an integral part of the MB and cannot be replaced or upgraded. Instead, look to see WHY you are running slow. How much memory do you have? With XP, you need 1GB, with Vista, you need 2GB. With any less, your machine will bog down.
7/4/2009 1:52:01 AM • Acer Aspire... • Answered on Jul 04, 2009
Laptop camera doesnt work
well you could try a few things. Don't know what the problem is. But try replacing the battieries, try resetting the camera, don't know what the problem is since you didn't state but a few things you could try.
4/15/2009 11:37:21 PM • Acer Aspire... • Answered on Apr 15, 2009
Acer Aspire E1 571 not charging battery.
Question edited for clarity and toss in a few CAPS. Question moved to Acer Aspire category. There a few issues that can cause this, the obvious one is that the battery has failed internally, but it can also be a charging software issue. Try this. Unplug from the mains supply. Remove the battery. Leave the computer for 2 hours. Press and hold the power button for a full 2 minutes. Replace the battery, plug back in, count to 10 and power it back up. Has the motherboard battery ever been changed? They are critical to the health of the motherboard and the machine in general.
Aspire E1-571 Plugged in not charging
Acer Community https://community.acer.com > ... > 2016 Archives Aug 20, 2016 - Hi, I have been having a quite critical issue with my laptop recently.
Acer Plugged In Not Charging
Driver Easy https://www.drivereasy.com > ... > Common Errors Apr 21, 2021 - This plugged in not charging problem may occur if you are using the wrong battery driver or it's out of date. So you should update your battery ...
Acer E1-571, Charging problem
Tom's Guide Forum https://forums.tomsguide.com > threads > acer-e1-571... Feb 10, 2019 - Hi there, I have a acer e571 laptop and i am facing a battery charging problem, whenever i plug in charger it start charging for 10 to 15 seconds and start. 1 answer · Top answer: It could also be the charger. The fact that moving the cord made a difference makes me think it might be. Also, have you tried charging it when the laptop ... My acer e1 570 laptop won't charge - Tom's Guide Forum Feb 7, 2017 I have an Acer Aspire E1-571-6837. It will not charge the ... Aug 25, 2016 Hi my acer aspire E1-571 won't turn on. I plugged it in and it ... Mar 9, 2018 More results from forums.tomsguide.com ..
4/18/2024 10:53:10 AM • Acer Aspire... • Answered on Apr 18, 2024
2answers
Access outlook
what password computer or outlook Reset an Outlook password to keep your program secure. A Microsoft Outlook password keeps your email account secure from unwanted intrusion. When you wish to reset your Outlook password, you must perform a multistep process to change your password first with your Internet Service Provider (ISP). The password with your ISP mail server must be the same as the password you set in your Outlook program in order to send and receive emails. Call your ISP and request a new password for your account. Write down the password after you receive it to ensure you do not forget it. Open your Outlook program, click the "Tools" tab and then select "Email accounts." Select "View or change existing email accounts" and then press "Next." Highlight the email account you wish to change (if you have more than one email account) and press "Change." Enter the new password you just received from your ISP into the appropriate fields (entering it twice). Place a check mark beside "remember password" if you want Outlook to remember your password each time you log in. Click "Test Account Settings" to make sure your account works with the new password. Press "Finish." I forgot my Outlook password http://office.microsoft.com/en-us/outlook-help/i-forgot-my-outlook-password-HA001113690.aspx
12/25/2023 6:14:52 AM • Acer Aspire... • Answered on Dec 25, 2023
My acer aspire m5100 desktop will wont do a start up beep and nothing on the screen
If you have no internal hard drive installed you won't get it to work correctly as the hard drive is where the data is stored for the operating system.
10/2/2022 2:12:57 PM • Acer Aspire... • Answered on Oct 02, 2022
Prendo la pc acer y se apaga vuelve a prender y se apaga y asi sigue
Estimado Carlos, Cuando la PC se apaga poco tiempo despues de terla prendido puede ser una senal de sobrecalentamiento del procesador. Si es una PC desktop, puedes verificar si el disipador de calor de aluminio y su ventilador estan colocados correctamente sobre el procesador y si el ventilador esta' funcionando. Si es una laptop, debes verificar si cuando la prendes el ventilador de las rejitas de ventilacion esta' suenando. Un ventilador que este' parado o con baja rotacion puede ser una de las causas del sobrecalentamiento. Pero, en los dos casos, si no es problema del ventilador del procesador, lo que hay que hacer es lo siguiente: 1 - Desarmar la computadora, y sacar el disipador de calor com mucho cuidado de sobre el procesador; 2 - Limpiar bien entre las ranuras del disipador de calor, sacandose todo el polvo y suciedad del mismo ya que el polvo ayuda a mantener el calor y sobrecalentar el procesador; 3 - Limpiar muy bien las rejillas de entrada/salida de aire, sacandose todo el polvo y suciedad, 4 - Rearmar el disipador sobre el procesador, pasando entre ellos una delgada camada de pasta termica plateada, que se puede comprar en tiendas de suminsitros y partes de computadoras (NOTA: no instale el disipador sobre el procesador sin pasar la pasta termica, porque podra' seguir sobrecalentandose); 5 - Rearmar la computadora. Caso usted no tenga facilidad en armar y desarmar la computadora, seria bueno contactarse con un tecnico de su confianza para hacer ese trabajo para usted. !Espero que esa respuesta pueda haberle sido util! PD.: Como ese sitio web solamente accepta caracteres en Ingles, la acentuacion no puede ser utilizada normalmente... Saludos, Miguel Luiz Martins
6/30/2022 3:55:50 PM • Acer Aspire... • Answered on Jun 30, 2022
Acer Aspire 3690-2710 Notebook Logo
22 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
camera acer aspire 3690 2710
  • Computers & Internet
