20 Most Recent
Compaq Armada 1573D Notebook Questions & Answers
Al encender mi computadora me pide de inmediato
o open the BIOS Setup screen:
Turn off the computer and wait five seconds.
Turn on the computer.
When the first screen displays, immediately press the F10
key if your computer was built in 2006 or later (came with Vista or Windows 7). Press the F1
key if your computer was built before 2006 (XP or earlier). Press the
key once every second until a BIOS Setup utility screen opens.
NOTE:
On some Compaq Presario computers (before 2002), press the F10
key at the logo screen.
Use the keyboard to move through the menus.
- Then disable the Administrator PAsssword
My laptop Compaq Armada 1573D dosnot see the added
Are you sure that the new memory is fully seated? Did both side clips click tight into place against the memory chip? If this is does not solve the problem move on to step 2. Remove the original memory, keeping the new memory in place. Restart the computer. If there is nothing wrong with the memory, then i should recognise the new memory w/out any problem. If you can not boot due to "no memory present" or some similar error message then the memory chip is no good or unrecogisable by your laptop. If the chip is good and the computr starts w/no problem, then reinstall the original memory chip and restart the computer. If the problem persists the two memory chips are incompatible.
Here is what crucial.com says you can install in you compaq armada.
http://www.crucial.com/store/listparts.aspx?model=Armada%201573D
Please let me know if this solves your problem, you can contact me at
[email protected]
John Kariotis
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
