20 Most Recent
Panasonic Toughbook 34 PC Notebook Questions & Answers
Upgrading Panasoic Toughbook model CF M34
ok...well..that may mean that the bios and operating system are incompatible...can you provide the revision of the bios and the operating system and we will see if they match up?
10/17/2008 5:17:46 PM •
Panasonic...
Answered
on Oct 17, 2008
Screen upside down on a panasonic CF-T8
On any Panasonic Toughbook you can rotate the screen as follows:
Hold down the "CTRL" and the "ALT" keys and while holding down
these two keys press the "UP Arrow" key and then release all
three keys. This will reset the screen so it is right side up instead
of upside down.
Good Luck and regards from:
Richard, Authorized Panasonic Canada Toughbook Dealer since 1989.
P.S. The arrow keys look like this: The up arrow is the one on the top
4/6/2018 5:40:18 PM •
Panasonic...
Answered
on Apr 06, 2018
Screen stays dark
On ALL Panasonic Toughbook Models,
if the screen stays dark I would shut-off the
Toughbook and connect an external monitor
to the VGA port (15-pin female connector),
which is usually BLUE in color.
Make sure the monitor is ON first, then
turn ON the Toughbook.
If the monitor comes on then your problem
is the backlight or possibly the inverter of the
screen.
If no image is shown on the external monitor
and the screen stays dark and you cannot
hear any startup (ie. Windows) sound, then
your video card may be defective. Very few
Toughbooks fail this way since they are
normally very very relaible but it can happen.
Good Luck
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
2/18/2016 4:50:23 AM •
Panasonic...
Answered
on Feb 18, 2016
Laptop dies when unplugged
Panasonic Toughbook PC Laptops usually have
very reliable battery pack. When your unit is plugged-in
but the Power is OFF, you should see an LED light as follows:
RED FLASHING: Means the battery needs replacement.
Orange/Yellow Solid: Means battery is charging.
Solid Green: Means battery is fully charged.
NO Light AT ALL: Means that Battery Pack is missing.
There is also a battery calibration utility on all Panasonic
Toughbook PC's manufactured since 2004. This is a factory
installed software and is only present in factory units.
This software may also be downloaded as a driver from the
Panasonic Toughbook website as follows:
http://pc-dl.panasonic.co.jp/dl/
Check also in the bottom right hand corner under
Windows for the battery Icon. This will indicate if
the battery is charging, present or not present,
and under Windows 7+ will indicate if the battery
needs to be replaced or not.
Good Luck!
Regards,
Panasonic Toughbook Authorized Dealer since 1989.
2/8/2016 5:27:55 AM •
Panasonic...
Answered
on Feb 08, 2016
