20 Most Recent
Acer 3003WLMi Notebook Questions & Answers
I was told the motehrboard was shot, is there any
I've repaired alot of laptops, including their mother boards. Online I see not many parts avaliable for this unit, in fact none of my suppliers carry the motherboard. You can check my web site
www.micromendllc.com. The diagnosis won't cost you anything and if I can't fix it I can dispose of it properly and send you the disposal receipt. Computer disposal to a non profit organization is deductable.
How do i move space from d to c drive
Drive C is your hard drive. drive D is a removable drive. What do you mean by removing 'space' from drive D to C?
.If drive C has insufficient space, the only way to remove space from D tom C, is to transfer data from the hard drive to the removable drive and then erase the data from the C drive. Did you try a disc cleanup? or Fragmentation?
How do i know if the battery is any good
Hi there you can right click on the desktop go to the power settings and look for the battery and do a status check on it if it is discharged or low and it has been plugged in for a long time and the pc has been showing that it is being charged i would probably say that yes the battery is going bad
Notebook and TV Connection
You should have a svideo plug on the back of the laptop, and if you have a svideo input on the tv you run a cable bewteen the 2 and you can watch it on the tv.
How to disable Laptop battery?
I really never seen such a problem.Your keyboard and mouse doesn't work !!! it only work when you remove the battery of the notebook ??? Do you mean bios battery or a noraml laptop battery ?? Give us more detail.
takecare.
Theknack
Desktop will not load
Follow this guide its pretty simple. You need to set it back to your cpu's last known good config, here is a link of directions. -http://www.computerhope.com/issues/ch000626.htm
Good luck.
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
