20 Most Recent
Brother MFC-J5910DW Color Inkjet All-in-One Printer Questions & Answers
Maintenance mode in brother mfc 5910 dw
Robbin, your anwer is wrong, those kind of codes are usually not provided in the owners manual. I had a bad inyector obstruction problem on another Brother and the support provided me a maintenance code to access a hidden menu with "heavy" cleaning options that don't appear in the manual.
7/31/2021 11:59:28 AM •
Brother...
Answered
on Jul 31, 2021
How To Change Language From Germany To English
Enter maintenance mode -
Press menu & *2864 in this manner
Wait for the machine to display "IIIIIIMAINTENANCEIIIIII " on the LCD. Press 74, follow by 0003 (Germany), press MONO START, wait for IIIIIImaintenanceIIIIII on display. Press 99 to exit.
7/30/2021 12:03:15 PM •
Brother...
Answered
on Jul 30, 2021
Magenta ink not detected even though new cartridge
When replacing a cartridge also check the contacts on the cartridge and in the printer. They should be clean and shiny. One spec of dust can spoil the fun. When the contacts are clear an the next cartridge is having the same issue it could be the printer has a cable or contact issue, or even the logic board can be defect.
4/21/2015 10:09:49 AM •
Brother...
Answered
on Apr 21, 2015
Reload paper on lcd
Make Sure You choose the right paper type like : A4 , A6 .....ect
And make sure to Match The Paper in the option of The Printer With the paper You are using in the paper tray
my regards
11/11/2014 12:37:32 PM •
Brother...
Answered
on Nov 11, 2014
Brother MFC-J5910DW printer wont fax
That message usually means you are not connected to a "live" phone line. Make sure the line is "hot" -has dial tone. Be sure that you have the line plugged into the correct opening marked "input", not the one that you plug a phone into.Good luck!
2/28/2013 10:20:02 PM •
Brother...
Answered
on Feb 28, 2013
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
