20 Most Recent Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Questions & Answers
LCD screens do not work the same as CRT tvs no vertical output IC, you have a screen fault which would need the screen replacing
Toshiba REGZA... | Answered on Oct 10, 2017
Get the estimate. When your insurance company sees it, believe me, they won't buck at replacing your TV _especially since the prices of TV's have come down over the years while the quality and resolution has skyrocketed. . .
Toshiba REGZA... | Answered on Jul 29, 2017
Tries tv unplug,replug it back like about an hour later.Go into tv menu goto PICTURE go down to do resetting.To resetting the tv Tuner signal board back to factory setting,now it should be working a gain.If still have the same result.Than the manual control PCB board like power,volume - + so on.. is short and the causes.Tries wwebsites like Shopjimmy.com,Ebay.com to buy a furbish Manual control PCB bosard for the replacement.
Toshiba REGZA... | Answered on Aug 25, 2016
The dish remotes only have a limited number of codes, if not there remember not all remotes will program all sets....
Toshiba REGZA... | Answered on Jul 01, 2016
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Sky don't list a specific code for the 26A3000R, but there are some generic codes for Toshiba TVs with a Rev 4 remote:
0536, 0581, 0063, 0473, 0530, 0746, 0121, 0742, 0173
Try each of the above codes until you find one that works the power and volume functions. If you have no success or you need code entry instructions, please post back and I will try to assist you further.
Regards,
BElectric
32inch lcd toshiba regza the screen has a yellow tint
Toshiba REGZA... | Answered on Apr 26, 2016
how old is this tv?
Toshiba REGZA... | Answered on Apr 25, 2016
HAHAHA Melissa shaking a TV is not the way to find out what the problem is take it to a repair shop for an estimate then decide if buying a new set is better than repairing
Toshiba REGZA... | Answered on Nov 22, 2015
Check and replace its tuner. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Toshiba REGZA... | Answered on Nov 13, 2015
If you are connected to an HD cable box or satellite box via component cables, make sure they are firmly seated at each end.
Toshiba REGZA... | Answered on Sep 05, 2015
Sounds like fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Toshiba REGZA... | Answered on Aug 03, 2015
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
356 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
any way get rid shadow marks or burn
  • Televison & Video
