20 Most Recent
LG RZ32LZ55 32 in. HD-Ready LCD Television Questions & Answers
Poor picture
its a mainboard issue .It can be fixed easily by replacing the mainboard or the hard way by fixing the excact one (the second option requires advanced electronics and expertise
GOT SOUND BUT BLACK PICTURE
try toggling the user brightness controls, if this didn't work, the inverter board is most probably the culprit, this is the part that supply high voltage to the light that illuminates the backdrop of LCD screens, consult a qualified tech to repair or replace this particular part. ;-)
I have connected my VHD
The tv is capable of displaying 720p and 1080i HD pictures. But that box was designed to accept for use only HDCP capable connectors - the DVI from your tv isn't one so the image is automatically downgraded to SD wide.
To get an HD image you will have to use the analogue RCA Component connectors plus the audio ones.
Problem with the LG RZ32LZ55 32 in. HDTV-Ready LCD
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
LG tv switched on and no colour everything else
Tries unplug,replug both tv and cables or satalites boxes an hour later.Tv should reset it self back to factory,pay boxes upgrade it softwares.The tv should work,back to normal.Not, take another tv test that incomming brocasting signal cable.If the incomming brocasting signal is good.Than the tv Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
How do you connect the Virgin VHD box to LG RZ32LZ55
All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
