20 Most Recent Samsung LE40R73BD 40 in. HD-Ready LCD Television Questions & Answers
2answers
How to watch movies from usb
If supported by your tv simple put a movie in the root of the USB stick in .avi or .dvix format then put stick in the tv and it would start the usb player function
3/27/2020 6:34:02 AM • Samsung... • Answered on Mar 27, 2020
How do i get my color back in my 40 inch samsung lcd tv
The problem is the T-con.
There is a faulty chip and need to be replaced.
Price is about 30-50€
11/24/2019 8:51:02 PM • Samsung... • Answered on Nov 24, 2019
2answers
On my samsung LE40R73BD the picture goes blank after about 30 min. but sound is ok. Please advice
I you can take your tv apart and take out the power supply you can send it in here Samsung BN44 00134A Power Supply REPAIR SERVICE 59 96 Global flat... to have it fixed before it quits completely.
11/6/2019 4:42:20 AM • Samsung... • Answered on Nov 06, 2019
2answers
When you turn on the television when it is on
When you buy a samsung, you buy a LED TV with a panel manufactured
by the company "S - LCD" which belongs to 50/50 % sony and samsung.
The S - LCD company is fully driven under samsung engineering.
Today, sony seems to buy their panels from "sharp corp" and trying to
seperate from samsung due to the cold war (high competition ) between
them.
Just go for the samsung UN32C6500 32" 1080p LED HDTV.
Theres no better picture quality you can buy for 32".
Good luck...
10/25/2019 2:47:35 AM • Samsung... • Answered on Oct 25, 2019
My Samsung Model LE 40A686MIFXXU has no manual.
Call1-800-samsung or download it online from samsung.com Russmann.
2/27/2019 4:22:06 AM • Samsung... • Answered on Feb 27, 2019
Samsung LCD T.V. Problem
You can try samsung.com or you can call 1-800-samsung and try to get to the ECR (executive customer relations) department. They are the people that might be able to help.
12/26/2018 8:11:32 AM • Samsung... • Answered on Dec 26, 2018
Samsung 46" lcd tv. Turned on tv and it made a
If it's new and has a warranty, take it back to the dealer and exchange it for a new one. There are no repairable items internally. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
1/6/2018 1:53:53 PM • Samsung... • Answered on Jan 06, 2018
Hi I have a samsung lcd tv (LE40R7) The picture
It could be some issue in the box itself; e.g. signal/video processing circuit (some cable/satellite/set-top boxes develop weird faults in this area when they get hot which affect channel reception/signal). Resulting in 'digital interference' affecting pictures on-screen. ~ You could also try another device on your TV (e.g. a DVD player if you have one handy) and see if any issues occur on-screen. If the set does not exhibit the same behaviour with a DVD player, chances are your cable/satellite/set-top box is the likely suspect. (the above suggestion is simply to determine whether the problem exists in the TV, the box, or both) ~ If it is proven that the box is indeed the culprit, you may have to consider replacing it with a new one as these are cheaply designed and generally non-serviceable.
12/24/2017 4:22:33 AM • Samsung... • Answered on Dec 24, 2017
My vizio tv will not turn on
I have repaired many of these over the years. Vizio s have regulators on the main board that have been failing causing this problem. You can verify that the power supply is working by the Vizio em-bloom lighting up on the front of the set. Hope this helps. :)
4/29/2017 5:00:57 AM • Samsung... • Answered on Apr 29, 2017
No color on samsung lcd tv even after factory reset
hi if you bring the menu up and it's clear then you have a tcon board fault, if the menu is the same as the picture then you have a mainboard problem, thanks shaun
3/10/2017 3:28:32 PM • Samsung... • Answered on Mar 10, 2017
Our samsung television has stopped
Possibly capacitor failure in power supply... shouldn't be too expensive to get repaired
5/1/2015 6:40:07 PM • Samsung... • Answered on May 01, 2015
HOW FAR CAN THE PEDESTAL STAND 'SWIVEL'? I CAN GET ABOUT 15 DEGREES EITHER WAY - IS THIS THE LIMIT OR CAN I ADJUST TO INCREASEDEGREE OF 'SWIVEL'?
I believe this is the limit, physically altering the engineered base for this television may put it in danger of falling or breaking. It's a 40 inch LED TV and really not that heavy, perhaps you could look for a lazy Suzann type of base that you could put beneath the TV to give you more extreme swivel capability.
4/18/2015 5:31:39 PM • Samsung... • Answered on Apr 18, 2015
How to access tv menu from tv without using remote ?
You should have its remote control to access its menu options. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
7/22/2014 2:09:23 PM • Samsung... • Answered on Jul 22, 2014
Hdcp problem with sky
You can get help here... https://contactus.sky.com/uk
7/21/2014 4:27:24 PM • Samsung... • Answered on Jul 21, 2014
Why won't my Samsung LN40C500F3FXZA turn on?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
7/3/2014 8:37:51 AM • Samsung... • Answered on Jul 03, 2014
Samsung plasma power indicator light flickering
This is problem with power supply board .You need to replace electrolytic capacitors in power supply.(see image).Good luckeae0d3e1-1260-4d93-bdae-f47e56f73f19.jpg
5/13/2014 10:41:07 PM • Samsung... • Answered on May 13, 2014
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
313 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
far pedestal stand swivel get about 15
  • Televison & Video
