20 Most Recent
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Questions & Answers
Samsung lcd tv keeps clicking but won't turn on
It most likley is the power supply on the TV itself. There are 4 capasitors that are known to go out. You can tell this by the tops popping out or black goo coming out. You can buy everything you need at Radio Shack. I spent 22$ for soldering iron and everything I needed. I have posted pictures here. I also watched some videos on desoldering and soldering on a circuit board - very helpful.
http://picasaweb.google.com/DerteSanchez/Repair?feat=directlink
11/10/2022 9:13:03 AM •
Samsung...
Answered
on Nov 10, 2022
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it
on.
Solution: I just had one of these come in. I opened it up, and found
the U501 capacitor a little suspicious looking, in that it had a
deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I
replaced it with a very good quality 1000uF 16V electrolytic 105degC
10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to
turn it on, the LED was yellow for a second, then green, then I got a
picture, and it appeared to work great. I then asked the owner a week
later how it was working, and they said it was working just like new!
4/20/2020 6:12:59 PM •
Samsung...
Answered
on Apr 20, 2020
Samsung LCD "keys locked"
Hey it taken me a few years to find a solution to this problem.I also own a Samsung syncmaster 2032mw.BTW you must hold / use the "Menu key on the side of the TV", as holding the remote key dosen't work!!Many thanks dopeNL
11/26/2019 12:19:49 PM •
Samsung...
Answered
on Nov 26, 2019
No manual
hi there...is very easy to get manual for your samsung...just write the type of your samsung (ex: Samsung LE32R74BDX HDTV 32 inc) go to samsung website..choose support/download. find your tv model and if there manual download as pdf you can download to your pc.
or if you want to know speck of your tv go to product line and find your model tv and press enter they will show you the spek of your tv...
10/31/2019 1:52:52 AM •
Samsung...
Answered
on Oct 31, 2019
Samsung HPS 5073
Unplug TV, take off the back. One each board there will be capacitors. the tops are flat unless one has blown then it is bubbled up. If you find one that is bad, copy the number and search the internet for a replacement. Unsolder and remove the old one ( there is a line drawn on the negative leg, mark the neg side on the motherboard so you can replace the new one the same way). Now solder the new one back onto the board. This worked for my TV, hope it helps
6/1/2017 4:12:09 PM •
Samsung...
Answered
on Jun 01, 2017
The television does not work.
Unpluging the set for about fifteen minutes or to see if that helps, if that doesn't do it, then it is your power supply board.
3/25/2016 8:14:13 PM •
Samsung...
Answered
on Mar 25, 2016
Reset code for le32r73bd - OTHER THAN INFO, MENU, MUTE, POWER
Jan 2016 --- Panzo's solution worked a treat, just remember to go into analogue, press buttons quickly, navigate to reset (option#12) and press left arrow which will remove the snow effect in analogue.
Thank you, and the rescanning worked without a hitch. Whew thanks again
1/7/2016 8:17:43 PM •
Samsung...
Answered
on Jan 07, 2016
Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
11/30/2015 10:04:38 PM •
Samsung...
Answered
on Nov 30, 2015
I'm trying to connect a WDTV to my SAMSUNG
I had the same problem. Had to connect using the composite cable, when to settings, changed it to HDMI. This turn the display on my TV off again. Then plug in the HDMI and it worked!
I also expected it to be plug and play... Hope this works for you...
8/21/2014 5:53:48 PM •
Samsung...
Answered
on Aug 21, 2014
