20 Most Recent Samsung LE40R74BDX 40 in. LCD Television Questions & Answers
UNSCREW the FOUR (4) screws on the back panel (marked with an "S" next to their recessed holes.
Work with the panel screen-side up (ie on its back - we did it with the LCD on the bed), and just JIGGLE the stand back and forth until the screws drop out. This make take some doing, but using force is a no-no (as the screw mounts are only plastic). Obviously the screws MUST be undone, so just keep unscrewing them while someone else jiggles for you.
Thats it. The plastic cover (from the manual & warranty bag) covers the hole.
Samsung... | Answered on Aug 23, 2018
Failing power supply
Samsung... | Answered on Nov 28, 2017
hi when fitting an new aerial line you need to put a splitter in the line.
4963215_1-oo4k03phwtyaxld0gomgkgbv-2-0.jpg it looks like this. they say satellite/tv on them this will stop interference from the boosters and the tvs on the same line, you connect it on the main arial line. you can then use both boosters if signal is weak but most digital aerials are good enough without them. it you have the right arial for your area. there are meany sizes. but say you are 15 miles from your tower then use a small aerial has the same fitting as this pic. that is out side aerials, inside aerials ie in loft you need a high gain aerial , long type. hope this helps. also if the aerial is not lined up it will not get great signal there is an app you can use on iphone or androids, tables etc to help you position the aerial in the right place it's called Uk aerial alignment . tool on app shows you the towers in your area and the best ones to use and shows you the aliment to the tower for best results. good luck
Samsung... | Answered on Jun 23, 2017
Possibly the capacitors in the power supply. You can identify the bad ones by their bulging tops. If you have the wherewithal, you can replace them for about $10.00 or less.
Samsung... | Answered on May 09, 2014
Samsung LE40R74BDX 40 in. LCD Television Logo
235 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
lcd screen samsung le40 86 bdx xeu same
  • Televison & Video
