Hello Sandi, According to the product information you provided in your post, the following information should be able to provide you with the information needed to help you remove and replace the ink cartridges for your printer.
Ink Cartridge Removal Steps:Keep your printer plugged in and on during this process.
1. Open the cartridge access door. The carriage moves to the center of the
product. Wait until the carriage stops moving before proceeding.
Illustration of cartridge access door2. Each ink cartridge will have plastic tabs located directly in front of them. Press in the tab on the front of one of the cartridges, and then pull it out and up to remove it from its slot. Once you have pressed the tab, you then pull up and out on the cartridge and it should come out easily.
Illustration of process:3. Repeat this step to remove all cartridges from their slots. Remember that each ink cartridge will have to be removed individually if your printer has more than one cartridge.
Replacing the cartridge with the new one:1. Remove the ink cartridge from the packaging and then remove the protective covering.
2. Hold the ink cartridge in the same position as you removed the old ones. Push in and then down on the new ink cartridge which should lock them into position with the tabs automatically and you will you will usually hear a clicking noise when this is done.
3. Close the cartridge access door. The printer will automatically reposition the cartridge print head assembly for you. This should complete the process and you should now be able to print. Some printer will ask or recommend that you print a test page so that it can calibrate the desired ink usage, position, darkness, etc. If this appears on your screen just follow the directions as prompted to complete the test page.I hope this provides you with a bit more clarity for removing and reinstalling your printer ink cartridges. If you have any further questions or need additional assistance, please feel free to ask. Have a good day.
