20 Most Recent Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Questions & Answers
Bios update
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=510
5/19/2014 7:11:34 AM • Mercury... • Answered on May 19, 2014
I need mercury PI945GVM-AGP motherboard drivers, anybody please help...
go to mercury.com web site type in your board KVM266PM-U then you will see download drives hit it then download all up date for your board look for support.
12/7/2013 12:44:08 AM • Mercury... • Answered on Dec 07, 2013
MERCURY MOTHER BOARD PVM266aM KEY LICENSE
See previous.
9/2/2013 10:31:41 PM • Mercury... • Answered on Sep 02, 2013
Mercury pvcle266m l audio driver
Which operating system and Desktop or Laptop computer ?........ Desktop If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it If this does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker. volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume. Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable). The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side. You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity. Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit. Dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for. Tick in either the all software or windows software box IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers. Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software. Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers. Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker. You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Laptop If your computer came with a motherboard disc the sound drivers could be on it Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it. If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop. You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit. dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Rather doing a driver hunt http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 Note: it will find all of your outdated drivers This is a free driver solutions which will automatically search for and find the correct driver You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. It might take some time being free
8/14/2013 8:18:21 PM • Mercury... • Answered on Aug 14, 2013
V046B02 C-Media AC97 Sound Codec Driver 18.6 MB pls sent mee
Free Codecs is available from this WEB site. www.free-codecs.com/index.htm
3/10/2013 6:19:24 AM • Mercury... • Answered on Mar 10, 2013
_kvm266pm_u matching sound driver
Hello you can download the drivers here:http://www.mercury-pc.com/downloads_list.php?productid=510Click on the c-media link for download, and you have to wait for 30 sec to download the driver.Best of luck :-)
2/18/2013 2:47:36 PM • Mercury... • Answered on Feb 18, 2013
3answers
Mercury kvm266pm-u sound driver
this includes all the drivers for your motherboard.
2/17/2013 5:46:25 PM • Mercury... • Answered on Feb 17, 2013
Mercury 15-v33-011098 drivers
Hello the drivers can be downloaded here:http://www.mercury-pc.com/downloads_list.php?productid=510If the driver does not fit the mainboard, find the mainboard here:http://www.mercury-pc.com/downloads.phpBy entering the mainboard number, or seach manualy by socket number.Good luck
1/23/2013 2:37:57 PM • Mercury... • Answered on Jan 23, 2013
Mercury motherboard driver
Hello download here at mercury:http://www.mercury-pc.com/downloads_list.php?productid=510Good luck
1/20/2013 2:18:42 AM • Mercury... • Answered on Jan 20, 2013
Mother board does not boot
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
1/8/2013 5:40:25 AM • Mercury... • Answered on Jan 08, 2013
3answers
I lost my mother board
here it is...
Download this software : CLICK ME
and this is the key : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
Instruction :
* install the software you download and if ask for the registration,just enter the given above.
* click SCAN to check all drivers if its update.
* now choose your desire driver or wish to update then click install if download complete.
(if pop-up some installation manually,just do so.
* reboot you pc and check if your webcam is working... good luck.
1/4/2013 9:01:50 PM • Mercury... • Answered on Jan 04, 2013
3answers
Mercury KOB P4M266 NDFSMX maindoard drivers
mail to [email protected] , if u still need. i have the same board and have the drivers.
11/20/2012 9:40:42 PM • Mercury... • Answered on Nov 20, 2012
2answers
I need free mercury motherboard
You can download the audio, video and device drivers from Mercury WEB supportsite, select your model motherboard to download :- http://www.mercury-pc.com/downloads.php
11/20/2012 9:38:41 PM • Mercury... • Answered on Nov 20, 2012
2answers
Pls give drivers for the
Please type "Mercury KVM266PM-U Motherboard Driver free Download" in Google Search... After searching is complete, you will find the categories of Drivers... Ready to download.... thanks
8/5/2012 8:33:02 PM • Mercury... • Answered on Aug 05, 2012
Ms7525 vga driver
Hi there, the MS-7525 is an OEM-branded Motherboard provided to HP and Compaq. If your computer is an HP or Compaq computer, look at the Model Number on the back, or underneath the computer, then go to the HP website.
http://www8.hp.com/us/en/support-drivers.html
Click on Drivers and Software, then either Detect your Product or type in the Model under "Enter Product Name/Number."
Once you've done that, your Motherboard should be listed in the Drivers section.
9/28/2011 10:32:19 PM • Mercury... • Answered on Sep 28, 2011
Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Logo
144 questions posted
Top Mercury Computers & Internet Experts
Jose Ramirez
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Mercury Computers & Internet
Most Popular Question
need mercury pi945gvm agp motherboard
  • Computers & Internet
