20 Most Recent
ASUS P5P800-VM Motherboard Questions & Answers
Cpu fan speed
1. Check if something like power supply wire have bangin in there.
2. Clean : Try to use lighter fluid to loosen and clean the dirt inside the processor fan but first disassemble the fan from the heat zinc of the processor. flip the fan and you will see the bearing and motor, drown it with fluid, and rotate the fan so the dirt will loose, after some spins, try to spill the fluid inside the fan. then assemble and test.
Motherboard power problem due to atx 12v cable
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
Asus p5p800-vm MOBO, when i
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Computer boost up but, keep rebooting over and
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Computer starts then shuts down no video no
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Hello, i'am italian a don't
Go to the BIOS. Just restart your computer and while restarting, keep on pressing "f2" key or the "del" key, sometimes "f8" until you see the option that you can go to setup/bios. On the Bios menu, just find there the option to disable the Chassis Intrusion detection.
P5p800-vm how to disable the
Put the new video card in, connect the monitor to it, boot in the BIOS and in there set the video card to Auto.
Please can you tell me,
there are 2 notches at either end of the ram module with 2 levers adjacent.
press down firmly on top of the ram until the levers secure into the slots
Okay here goes my story... I have a trouble in my
check SMPS providing power to Mboard to start(see mother board light on or not<green LED>)
then do all this things if smps is ok then check soun d beep if no beep take your board to hardware shop
Audio driver p5p800-vm series
Here is the Asus site where you can download the board drivers
http://www.asus.com/product.aspx?P_ID=oP18OIoOjkinxNiI&content=download
NO AUDIO
Hi, I'm not going to go into a
guessing game of why I believe the "Audio" isn't working; I just going to give you a quick and direct solution to the problem. Click on this site, and see if you can get your drivers "Updated." Next thing you can do is go to the [Start Menu], click on "Windows / Microsoft Updates" and have the necessary (Updates installed). "If this helps, let me know by Rating the Help, thanks."
http://www.nodevice.com/driver/P5P800-VM/get34074.html
