20 Most Recent
Traeger Industries BBQ070 All-in-One Grill / Smoker Questions & Answers
Treager BBQ will not get hot at all.
Ensure your fire box is cleaned out and ventilation holes at the base are not obstructed. Ensure the induction fan is operating and moving air into the fire box.
According to Treager FAQ:
"I've been noticing that my grill temperature keeps dropping lower. What is the problem?
You need to "true" your auger. To do this:
Run the unit out of pellets.
Remove the allen screw and nut out of the auger and motor shaft.
Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
Reattach auger and motor shafts using the screw and nut which you removed in step 2."
3/29/2023 8:00:21 AM •
Traeger...
Answered
on Mar 29, 2023
Traeger BBQ trips circuit breaker
Mine is doing the same thing, but it does it within seconds of turning it on. I'd assume you as well have the digital thermostat. I've narrowed it down to what I believe is the hot rod igniter (or the purple connector). Unplug it and it should eliminate tripping and order new part or get warranty part.
3/22/2020 5:28:00 PM •
Traeger...
Answered
on Mar 22, 2020
Treager is overheating
Make sure you are leaving it open long enough when you first turn it on. Everything in the smoke chamber needs to burn up before you begin. There also may be grease buildup in the bottom of your smoker that is catching on fire. If neither of these two possibilities work, contact Traeger support
https://www.traegergrills.com/support
1/16/2019 6:14:06 PM •
Traeger...
Answered
on Jan 16, 2019
Treager is overheating on smoke setting
1/16/2019 6:13:28 PM •
Traeger...
Answered
on Jan 16, 2019
New purchase Traeger 07E and
It is time/weight based programming not PID. You can still cook just fine in this range. Just watch your internal temps closely.
9/29/2017 5:13:30 AM •
Traeger...
Answered
on Sep 29, 2017
Where is the fuse located on a Traeger
The fuse is located on the back side of the control panel, in a light green plastic housing. It should have a spare fuse zip-tied to it, which will also let you know the location of the old fuse.
10/5/2015 3:52:39 PM •
Traeger...
Answered
on Oct 05, 2015
I keep getting an error msg. When it finally starts, it shuts off with the Err
Hi Terry,
This may help... ...from Treager's site
FAQ
My Unit Goes Out On Smoke
- Open the cooking chamber lid and remove cooking grill, angled drip pan and U-shaped firepot cover. Look and see if there is a large accumulation of pellet ash in and around the firepot. If there is, it will need to be cleaned out. Do this ONLY WHEN THE GRILL IS TOTALLY COLD! Replace U-shaped firepot cover, angled drip pan and cooking grills and resume cooking/smoking process.
- If this does not remedy the problem, please contact the Traeger Service Department."
From my personal experience, cleaning out the pellet ash is needed when the smoker will not hold a high temperature regardless of the thermostat setting.
In your case, the fire pot may be packed with pellet ash and pellets from the auger jamming.
Good luck.
6/2/2015 3:05:21 AM •
Traeger...
Answered
on Jun 02, 2015
Have a traeger grill and
So I got a ERR on my treager it end up being the controller thank god had a old one to test it good to know
4/13/2015 12:33:04 AM •
Traeger...
Answered
on Apr 13, 2015
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
4/9/2015 4:24:40 PM •
Traeger...
Answered
on Apr 09, 2015
GFI keeps kicking out I repleaced the hot rod,could it be the digitl thermomater
Could be that your auguris binding and putting heavy load on the motor. It could also be a bad GFI circuit. I doubt that your thermometer could put enough load on the circuit to cause the GFI to trip unless there's a big-time short in it. Could also be a short elsewhere in the wiring harness or fan motor.
12/10/2014 10:29:04 PM •
Traeger...
Answered
on Dec 10, 2014
Why my fan won't blow
The fan is a cheap part to fix if it is dead. Go to their website and order a new one unless it is under warranty.
12/9/2014 4:34:12 AM •
Traeger...
Answered
on Dec 09, 2014
Not smoking
Traeger grills just will NOT smoke at temps much above 200 degrees. I have to stand by my grill continually in the summer to keep opening and closing the lid to let the heat out. That also lets the smoke out. I also have turned the grill off and on to try to maintain the temperature at 180 degrees where it smokes best and cooks low and slow. It's less of a problem in the winter months. Then I find myself setting the temperature higher turning it from low to medium and back to maintain the temperature I want.
12/4/2014 11:18:07 PM •
Traeger...
Answered
on Dec 04, 2014
