20 Most Recent NetGear WGR614 Router Questions & Answers
Wont connect to internet
You need to reset the router if the lights are flashing. Press the reset button at the back of the router for about 20 seconds then release it. Now unplug the power for 20 mins as well and plug it back in. Make sure your connection is right. PC connected to port 1 and modem to WAN or Internet port.
12/29/2018 12:47:02 PM • NetGear WGR614... • Answered on Dec 29, 2018
2answers
Installing the router. when testing the
Hello.
You need to make sure your gateway, DNS IP address in entered correctly and your RJ45 connection has the Orange and Green light blinking..
Thanks
11/14/2018 10:30:22 AM • NetGear WGR614... • Answered on Nov 14, 2018
2answers
My netgear modem WGR614 router
Factory reset the modem and upgrade to the latest firmware.
Are you connected via ethernet or wireless?
11/14/2018 10:29:51 AM • NetGear WGR614... • Answered on Nov 14, 2018
2answers
Cannot connect to Internet.
The orange blinking light indicates that it cannot obtain the DNS server from your ISP (internet service provider). You must contact your ISP and check whether your service is active.
11/14/2018 10:28:50 AM • NetGear WGR614... • Answered on Nov 14, 2018
Cannot restore factory settings
You need to consult a qualified Technician.
4/17/2017 5:18:37 PM • NetGear WGR614... • Answered on Apr 17, 2017
Router (WGR614v7) does not get wireless signal
Call NETGEAR technical Support. If they cannot help try this http://technicalsupport.blog.friendster.com
4/3/2017 10:11:17 AM • NetGear WGR614... • Answered on Apr 03, 2017
Wgr614 disconnect
Please check your version WGR614v1 Product Support NETGEAR
3/4/2017 2:54:24 AM • NetGear WGR614... • Answered on Mar 04, 2017
0answers
3334444556
Be the first to answer 3/9/2015 10:38:39 AM • NetGear WGR614... • Posted on Mar 09, 2015Be the first to answer
How do I make this
No, you have a bad internet connection. Sort that out first, try not to use wireless connection until you have established a good fixed cable connection. Then test out the wireless connection.
3/8/2015 10:59:24 AM • NetGear WGR614... • Answered on Mar 08, 2015
Want to lock my netgear browser
Netgear is not a browser. It is a Router. For the sake of this question I would assume you were talking about the Router, what do you mean by "Lock"? You can change the default password, and no one will be able to access it. If you only want specific devices to connect to the router, you can: 1) Enable MAC Filtering 2) Disable DHCP, and assign Static IP addresses to the devices 3) Hide SSID (Not Broadcast it)
3/4/2015 8:18:15 PM • NetGear WGR614... • Answered on Mar 04, 2015
2answers
Driver for netgear wgr614v7
Go to netgear.com ,click on support and download the latest version,also go to Windows update .
5/22/2014 6:42:00 PM • NetGear WGR614... • Answered on May 22, 2014
PROLiNK H5004N ADSL Wireless Modem
Username: admin password: password
5/2/2014 7:41:47 PM • NetGear WGR614... • Answered on May 02, 2014
Wireless internet wont connect
Go to windows logo in search box type cmd in black screen type ipconfig /release when completed type ipconfig /renew try again if still no go do the following reset to factory default press and hold reset button during the whole process and only release when completed. 1)press reset button 30 seconds 2)remove power cable 30 sec 3)plug in power cable 30 sec and then release. You should no be set for 192.168.1.1 username admin password is password If all fails check to see if the box is checked for wireless
4/18/2014 5:51:02 PM • NetGear WGR614... • Answered on Apr 18, 2014
How do I get my Blueray and my TV to connect with the Netgear wireless?
First off you need to have a wireless connection,that being said if you have one then you will need to go to your device and let it search for your wireless router.Once that is done and you enter any password you may have on your router it should connect.I seen had issues with this because the wireless signal can be weak if so to resolve this use a POE (Power Over Ethernet) or a direct wire from your router and select a wired connection.
4/18/2014 5:00:52 PM • NetGear WGR614... • Answered on Apr 18, 2014
Blinking light
yes
11/21/2013 9:27:51 PM • NetGear WGR614... • Answered on Nov 21, 2013
manual
3answers
Forgotton name and password
have you tried admin and password? The defaults if you haven't changed them.
Or if you did.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
8/8/2013 6:23:47 AM • NetGear WGR614... • Answered on Aug 08, 2013
Download smart wizard instalation assistany wgt 624
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL - http://192.168.0.1 The default login = admin The default PW = password You can now change the default admin password and configure the wireless settings. Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access. Now apply these settings to the wireless card in your laptop/computer. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
3/8/2013 8:49:01 AM • NetGear WGR614... • Answered on Mar 08, 2013
NetGear WGR614 Router network disappears
I would replace it, or, put it on a power strip with a switch and switch off when not in use, switch on when you come in. Take a look at these: http://www.tigerdirect.com/applications/category/category_slc.asp?Recs=10&Nav='c:373'&Sort=4
2/27/2013 12:06:36 PM • NetGear WGR614... • Answered on Feb 27, 2013
Netgear wgr614 v10 router will no longer power on
It can be connection problem or you are doing wrong setup..check all cable which is connected with router..
2/15/2013 7:16:00 AM • NetGear WGR614... • Answered on Feb 15, 2013
NetGear WGR614 Router Logo
322 questions posted
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
download smart wizard instalation
  • Computers & Internet
