20 Most Recent Thermador 37 in. CET365 Electric Cooktop Questions & Answers
Sorry to say,but if there was an improper wiring,it could fry just about everything/anything.To repair it would be time consuming and probably cost about just as much.Labor for a repair center easily starts at $60/hour,maybe more.Repair centers have a parts price minimum markup of 20%.Unless you have a solder gun and a multimeter and solder to repair yourself,it would be a very wide range estimate considering the circumstances.It could cost $40,it could cost $400.If the display is not working especially and needs replacing,that is quite expensive.If you do have some of the equipment,I could guide you on a few things to check first.Although you say a few circuits,if you do not have the knowledge it may just be 1 circuit really,most likely input power to start with which is 2 diodes to check,then go from there.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
Thermador 37 in.... | Answered on Dec 05, 2010
did you stored any settings to become it like that then .unplug the device and then plug in and set all the settings properly again and check out.
Thermador 37 in.... | Answered on Nov 21, 2008
there is a control board under the glass where you touch to make it come on. some models were recalled. it you contact thermador they should come and take care of it for you
Thermador 37 in.... | Answered on Nov 25, 2007
It is common for electric coils on a range top to click/on/off. They are suppose to reach a certain heating range and when satisfied, they go neutral and when the demand for heat is needed, they become energized again.
Thermador... | Answered on Feb 09, 2018
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
Thermador... | Answered on Aug 29, 2017
Thermador 37 in. CET365 Electric Cooktop Logo
3 questions posted
Top Thermador Cooktops Experts
jasbo
jasbo
Eric Gundersen
Level 1 Expert
ray gallant
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Thermador Cooktops
  • Thermador Cooktops
Most Popular Question
burned out few circuits electronic
  • Cooktops
