20 Most Recent
ZTE Avail Z990 - Black at&t Smartphone Questions & Answers
Free imei unlock codes
you can easily get AT&T ZTE IMEI Unlock Code from zteunlockcodes.com, i got a very fast response and easy solution to unlock my ZTE phone and i found it to be the cheapest way to unlock my phone
thank you zteunlockcodes.com
Unlock zte z990g
Hi. You can unlock your ZTE Z990 AVAIL safer and easier using unlock code. You can get the unlock code for your mobile phone from
OnlineGSMunlock.Com at affordable cost with easy unlocking guide. Good luck.
My avail doesnt respond to touch
Try to perform hard reset by Pressing and holding the combination of the Power key+ volum up key+ Menu key when the phone is off. When it enters the boot loader mode use the volume key to scroll --> select wipe data and factory reset --> select yes and wait till the phone reboots.This would solve your issue... :)
At&t zte990 screen blacks out when making call
This may be due to some software issue.i suggest you to reset your phone that will solve any kind of issues facing with your phone.I have my phone where my display went black, and i performed the below steps. You can even try this
Press and hold the combination of the Power key+ volum up key+ Menu key when the phone is off. When it enters the boot loader mode of teh phone use the volume key to scroll --> select wipe data and factory reset --> select yes and wait till the phone reboots.
Microphone not working
If you are facing the microphone issue, then you can try resetting the device.1.Power off the phone.2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.3.Use "Vol+" and "Vol-" to move the cursor up and down.4.Move cursor to "wipe data/factory reset", press "Back" key to select it.5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.6.The data will be erased.7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.WARNING: All user data will be completely cleared; the phone will be in a factory reset status.
Avail z990 can't receive text messages
Please have a check with your service provider. If still no help, then try resetting the device.1.Power off the phone.2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.3.Use "Vol+" and "Vol-" to move the cursor up and down.4.Move cursor to "wipe data/factory reset", press "Back" key to select it.5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.6.The data will be erased.7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.WARNING: All user data will be completely cleared; the phone will be in a factory reset status.
Android avail stuck in boot screen
Please try resetting the device and check if it would help to resolve the issue.Power off the phone.2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.3.Use "Vol+" and "Vol-" to move the cursor up and down.4.Move cursor to "wipe data/factory reset", press "Back" key to select it.5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.6.The data will be erased.7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.WARNING: All user data will be completely cleared; the phone will be in a factory reset status.
Zte z990 phone keeps shutting itself off
Well, it really depends on many factors. I guess that you are using many apps at the same time (Background apps consume battery).Another possibility is that your battery is asking for a retirement. Replace it and see if the problem persists. You may need to take it to the repairman.
