20 Most Recent
Thermador PSC364GDZS Gas Cooktop Questions & Answers
Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
12/13/2013 9:38:54 PM •
Thermador...
Answered
on Dec 13, 2013
I have a 36" Thermador
Exactly what part you replaced.And was there any difference in the problem after and before replacing the part.
as per the problem the possible faulty parts can be Damaged igniter or faulty safety
valve.
1. The thermostat control.
2. The igniter.
3. The automatic valve (also called
the safety valve).
The thermostat, igniter, and safety valve
are wired in a series circuit.
• When the thermostat knob is turned to a
selected setting, electrical contacts in the
thermostat close applying power to the
series ignition circuit.
• With power applied, the ignitor begins to
heat. Electrical resistance in the ignitor
will decrease as the temperature of the
ignitor increases.
• Electrical current in the series circuit
increases in proportion to the drop in
ignitor resistance.
• The igniter limits the electrical
current in the circuit to 3.3 to 3.6 amps.
The surface temperature of the ignitor will
be between 1800° and 2500°F.
• When electrical current has reached the
proper amperage, the automatic safety
valve will open, releasing main burner
gas.
• The ignitor stays energized while the
burner is lit. Once the selected
temperature is reached, the thermostat
contacts will open and remove power from
the ignition circuit. The automatic safety
valve will close after a few seconds, and
the burner flame will go out.
----------And the burner will relight when temp-reaches down from selected.But if the safety gas valve does not open then it will not relight, or if the igniter is weak then it will not relight.The gas pressure is low then it will not let the cook top to relight.When you turn the selector off and turn on,the whole system works as it gets a flow of current.But its not working automatically as it should.Also other possibility can be selector switch/know itself.----------
This possibilities are to be checked.Keep updated.Thanks.Helpmech.
3/7/2011 3:34:34 PM •
Thermador...
Answered
on Mar 07, 2011
I have scratches on the edge of the oven in front
Use 3m Scotch brite #7447 or 220 grit sand paper depending on the severity of scratch. Always finish any sanding by blending with the #7447 pad. Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel.
DeBruce Polish also works on glass cook tops. We get DeBruce Polish at
debrucepolish.com.
4/29/2010 12:57:16 PM •
Thermador...
Answered
on Apr 29, 2010
Horribe stains left on whirlpool gas hob by domestic cleaner
We Use Debruce Polish on all our cooktops. Debruce also works on
stainless steel and polished granite, marble, porcelain, formica and
glass. DeBruce is non-toxic odor-less and eco-friendly. You can get
DeBruce on line at debrucepolish.com.
This stuff will do the job!!
8/23/2009 4:01:14 PM •
Thermador...
Answered
on Aug 23, 2009
I left cillit bang on the stainless steel hob too
Use appropriate solvents to remove the plastic. If you are skilled sanding in straight lines and matching the grain in your metal use 180 grit - 240 grit blending and using your eye. You could also use scotch brite #7447 purchase at an automotive store. This pad after solvent or used with it could remove the plastic or both sand and pad.
Debruce Polish is the best our there at maintaining a pristine finish and it is eco-friendly and odorless, we use this in all our properties AND the ceramic cook tops it is safe for glass. It also removes rust... we just love it. We find DeBruce polish at debrucepolish.com.
7/27/2009 8:15:27 PM •
Thermador...
Answered
on Jul 27, 2009
Range wont light
Hi
It sounds to me like a switch problem.
You should check the Gas Valve that correspond to that switch, and also check the Manifolds, there should be one manifold for each set of gas valve switches.
Hope this help.
Eddie Rentas
Tupper Lake NY
7/7/2008 12:06:02 AM •
Thermador...
Answered
on Jul 07, 2008
Some of the control knobs on my Thermador Rangetop PCG366W sink all the way in so that you can't see the writing on the knob, is that normal? If not, is there a fix for it?
Burners Do Not Start
Hand on burners
The Burners Do Not Start
There are several solutions for this problem:
The main gas supply may not be turned on. Make sure it is turned on.
Check the power supply and make sure the unit is plugged in and the circuit breaker has not tripped.
Make sure the burners are properly positioned.
The igniters may be dirty. Carefully wipe the igniters with a cotton swab dampened with water after they have cooled down. Gently scrape the soil off with a toothpick. Avoid exposing the igniters to excessive water as a damp igniter may not light up. Remove any lint that may remain after cleaning.
The ignition will be quicker if a cooking pan is on the grate. Ignite the gas at full and once alight, turn it down to around 50%. It should lock on within 6 seconds.
Does the burner click when the burner knob is in the ON position? If yes, you may have a wiring issue at the outlet that the appliance is connected to. Turn off the main gas supply and contact a qualified electrician to fix this.
Does the burner click when the burner knob is in the OFF position? If yes, check for the following:
1. Check to see if the burner cap is properly placed and the igniter is not wet or dirty.
2. Check to see if the regulator supplied with the unit is installed properly. The arrow on the regulator should be pointing to the appliance. Please call a professional installer
1/16/2023 6:59:14 PM •
Thermador...
Answered
on Jan 16, 2023
Two electric burnings on thermador cooktop not working. Can they be repaired
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges,the oven temperature sensor
is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
- If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
- On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
- Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
- Repeat the step above for the terminals "L2" and "H2".
- If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
- With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
- A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens usean electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
3/17/2020 7:09:00 AM •
Thermador...
Answered
on Mar 17, 2020
Have a thermador psc364gdzs the spark does not work for the gridle
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
8/29/2017 11:38:38 PM •
Thermador...
Answered
on Aug 29, 2017
