20 Most Recent
Apple Iphone 4s I Phone 4 S Factory Unlocked Sim Free 16gb - White Questions & Answers
Newnew
Contact the original carrier and see if youre illegible and they will take you from there!
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Reset forgotten password
You will most likely have to restore your iphone through itunes. You can do this but the only draw back will be losing any apps, music and contacts that are not saved or backed up through your itunes account. If you want to restore your iphone which is the only way you can bypass your passcode, you first need to connect your Iphone up to your itunes account through a laptop or PC. After the computer connects up to your phone, first press the power button and count to 3 and keeping the power button pushed in press and hold the home button. Keep both buttons pressed in until the iphone goes into recovery mode and than release both buttons at the same time. It may take 30 seconds. You should be able to restore your iphone and than you will be able to put in a new passcode. If you put it into recovery mode and you change your mind don't worry, just press and hold the power button until the apple symbol appears and than release it and it will take you back to the locked screen.
[email protected]
Make sure that you are using the same computer and icloud account when doing this. Also if on the cloud just sign in to it on the new phone and all things that you have synced should be synced.
iCloud Use iCloud com
Im trying to down load the paypal app on my iphone 4
Hello Patricia. I was looking at the web searching for a solution to your problem, or if anybody else have got the same problem. According to Paypal website, the app is suppose to be compatible with your phone model. Paypal for IOS support IOS 8.0 and up. Ifyou still can download the app I do suggest that you visit the Paypal forum @ https://www.paypal-community.com/t5/US-PayPal-Community/ct-p/US
IPHONE 4S CARD NOT SUPPORTED HOW TO GET THE CARRIER
There is more than an issue to cause this. 1st that some iphones are locked on a specific operators, with a contract for one or couple of years. after end of contract you can unlock the iphone at the operator and can use any sim card. 2nd the sim card it self may be damaged & cannot be read by iphone, please try it in another phone and see if it is working.
To know if your iphone is officially locked/unlocked by the model number, you can google it.
