20 Most Recent
Eureka 5856BVZ Boss Bagless Upright Cyclonic Vacuum Questions & Answers
My boss model 5892 brush will not roll
This unit has a reset button on the side of the hood. Recline handle, turn power switch on, pressing down in carpet mode, press reset buttonon the side of the hood, the brush should turn on.
What is the cause of
If it's a rattling type noise, its possibly something in the fan assembly, including a broken off piece of the fan.
It could also be something loose near the roller brush, including a piece of the belt.
I think it is missing
Remove the three screws on the top of the vacuum base. You may need to recline the handle to the lowest setting as if you are going to vacuum under a bed. Turn the height selector to the side (either right or left), lift off cover of base. Your belt area should be to the right side. Hook new belt on the motor shaft at the back...it kind of looks like a nail sticking out. Pull the brush roll out, clean off any thread, hair, etc. Place grooved end of brushroll in loop of belt, replace brush roll, stretching belt into place. Rotate by hand a few times to make sure belt stays straight.
Stopped suddenly, won't start back
Your vacuum has an auto shut off when motor gets hot. It comes back on after 1 hour & is cooled down. While it is cooling down, you want to check the following; look for either a blockage in either the main hose, or lower hose, or just need to clean the dust cup foam & filter, & check the hepa filter on the side of the vacuum.
