20 Most Recent
Gestetner DSm627sp All-In-One Laser Printer Questions & Answers
Gestetner 5308L error says set drum completely
Please open the front door carefully and open the right door also and then remove the photoconductor unit unit and reset properly.
If the problems persist , call an expert to check the sensor for you.
Best of luck.
5/25/2014 2:19:37 PM •
Gestetner...
Answered
on May 25, 2014
My Gestetner DSm622sp says it
Most machines just use regular or notebook hard drives available anywhere.
Just replace & format it inside of the copier menus.
6/20/2009 1:00:53 PM •
Gestetner...
Answered
on Jun 20, 2009
Gestetner DSM627 Service Code Problem
These SC errors are related to the Hard disk.
Re - enter SP mode: Clear, 107 and press and hold Stop button for 3 secs.
Enter SP 5832-008 and press #,(Mail Tx data) to initialize the HDD. Then switch off and on the machine.
If still with error, replace the HDD.
Attention not to change any others SP modes - very sensitive settings!
Good luck and please rate me, thanks.
2/19/2009 10:41:24 PM •
Gestetner...
Answered
on Feb 19, 2009
Gestetner DSM627
Have you tried the default UN and PW?
UN: admin
PW: password
9/12/2008 7:35:28 PM •
Gestetner...
Answered
on Sep 12, 2008
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
Sc 569 for ricoh mp 5500
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures: 1. Check or replace the harness of the pressure roller contact sensor. 2. Replace the pressure roller contact sensor. 3. Replace the pressure roller contact motor
SC 569 Error code in MP 5500
