20 Most Recent Ricoh Aficio™ SP-C210SF Printer Questions & Answers
2answers
How can I convert Ricoh development counter to pages
Best thing to do is contact Ricoh Services and Support (1-800-432-9787) for service. A Ricoh Tech/Engineer would need to go into Special Service to change the Accounting type preferences, as end-users shouldn't have access to this Special Service function. Additionally, once this change has been made, you cannot revert back; you can only change this setting once.
4/2/2015 8:17:19 PM • Ricoh Aficio™... • Answered on Apr 02, 2015
OUT OF CYAN AND WANT TO PRINT ONLY BLACK AND WHIE
go into properties and select black and white for starters
4/12/2014 3:03:01 AM • Ricoh Aficio™... • Answered on Apr 12, 2014
Cyan is out of ink and i want to print in only black and white
Susanne, Unfortunately almost all of the color lasers,except a few new Canon's,use the colors to make black. That way they can inflate how many B&W pages you can get from the blck unit. Sorry
2/13/2014 11:23:00 PM • Ricoh Aficio™... • Answered on Feb 13, 2014
How can I check the
The instructions for getting the page count for the C210SF should be the same as for the C231SF:
- Press User Tools.
- Scroll down until you see Reports Print.
- Press OK.
- Scroll down to either Configuration Page (2 pages long, prints in black and white) or Maintenance Page (1 page long, prints in color).
- Press OK.
Both the configuration page and the maintenance page will show the page counts. For page count instructions on other models of copiers or printers, check out ConfigPages.Blogspot.com.
8/21/2011 8:00:33 PM • Ricoh Aficio™... • Answered on Aug 21, 2011
RICOH Aficio MP W2401 FUNCTIONAL PROBLEM SC 401
Ricoh Aficio 240W Plotter Error Code SC 401-00
Copytechnet https://www.copytechnet.com > forums > 108927-rico... May 4, 2016 - On old Ricoh Aficio's SC401 used to be a Transfer error, but on the 240 its ID Sensor, could be dirty, could be old Dev, could be a loose ... Ricoh MP2352 SC401- Strange problem Jul 28, 2021 Error Code SC-401 Sep 12, 2014 ricoh mp 3352 - error sc401 Dec 11, 2020 Ricoh mp 2851 SC 401 Jul 11, 2017 More results from www.copytechnet.com
Error Codes > Ricoh > MP2553 > Code SC401
Printcopy.info https://printcopy.info > code=SC401 Code: SC401 · Description: Transfer positive electrode current error A transfer roller current leak signal is detected. · Causes: • High voltage supply board set ... Missing: W2401 ‎' Show results with: W2401
Error Codes > Ricoh > Aficio 2090 > Code SC401
Printcopy.info https://printcopy.info > code=SC401 Code: SC401 · Description: Transfer roller open error · Causes: • Transfer power pack defective • Poor connection between the transfer current terminal and the ...
2/15/2024 7:20:12 PM • Ricoh Aficio... • Answered on Feb 15, 2024
Hi, I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
  1. Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
  2. Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
  3. Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
  4. Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
  5. Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
  6. Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
  7. Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
  8. Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
  9. Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
8/6/2023 12:35:36 PM • Ricoh Aficio... • Answered on Aug 06, 2023
Ricoh Aficio. How I clear SC390 code? Print is clear, after 10 copies SC390 code is coming. How do I solve this problem please?
Question edited tor a lot more clarity and add MAKER, but NO MODEL NUMBER! All questions need full make and model.
Ricoh Aficio 200 - Error Code: SC390
PrintCopy .info https://printcopy.info > code=SC390 Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed. Missing: cod ‎' Must include: cod
SOLVED: How fix sc390 cod of ricoh
Fixya https://www.fixya.com > ... > Ricoh The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Error Code sc 390
Copytechnet https://www.copytechnet.com > 56632-sc-390-a Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ... Missing: cod ‎' Must include: cod
RICOH Error Code List - mtechsinfo.com
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF SC-390-2. Toner density sensor error. SC-391. Developer bias problem or FU103 on Aficio 550/650 Image storage address error. Aficio 551, 551P, 700, 700P. 14 pages
5/9/2023 3:30:03 PM • Ricoh Aficio... • Answered on May 09, 2023
Ricoh mp 4054 error code 554-01 how to solve this?
4/17/2023 5:29:20 PM • Ricoh Aficio... • Answered on Apr 17, 2023
Ricoh aficio sg2100n error code sc 20200
4/17/2023 5:28:27 PM • Ricoh Aficio... • Answered on Apr 17, 2023
Ricoh MP C5502 Color Laser Multifunction Printer - Ricoh. What could cause paper not registering on the MP C5502 cutting top part of the image please?
Question edited for a lot more clarity and toss in some CAPS. Question moved to maker category. Printer set to wrong size paper. Computer word processing program set to wrong size. For example Letter size paper in Printer and Legal size in the Settings of what is saying to print the document. The paper is too small.
2/19/2023 6:43:38 PM • Ricoh Aficio... • Answered on Feb 19, 2023
Ricoh Aficio SP1100sf: good day, anyone knows where its backup battery is allocated or, better, has got its service manual?
The backup battery for the Ricoh Aficio SP1100sf is located in the control panel. The service manual does not provide specific instructions on how to replace it, but it does provide general instructions on how to maintain and troubleshoot the printer.
4/19/2022 11:09:40 AM • Ricoh Aficio... • Answered on Apr 19, 2022
2answers
How to fix ricoh sc202-00 error code
replace the polygon mirror motor
2/21/2022 10:21:53 AM • Ricoh Aficio... • Answered on Feb 21, 2022
Ricoh aficio sp c240N with error code sc397
hi SOURCE: ricoh aficio 2022 error code sc542 1. Mode(Yellow Button) 2. 107 3. Press STOP Button for 3 second (RED Button) 4. Copy Sp 5. 5810# 6. Excute 7. Power Off 8. Power On
12/9/2021 3:43:12 PM • Ricoh Aficio... • Answered on Dec 09, 2021
MP c2051. What does error sc364 indicate?
TD sensor (Vt low) error 2: K
12/22/2020 10:09:17 PM • Ricoh Aficio... • Answered on Dec 22, 2020
How to fix a 991 and 992 code on a mp 2501
that is software program error. u need to update firmware
4/16/2020 10:21:01 PM • Ricoh Aficio... • Answered on Apr 16, 2020
Ricoh Aficio™ SP-C210SF Printer Logo
8 questions posted
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
convert ricoh development counter pages
  • Office Equipment & Supplies
