20 Most Recent
Ricoh Aficio CL7100 Printer Questions & Answers
What is replace color cpu toner?
Could the message have been "Replace color PCU (Type A)"? In that case, you need to replace all three color photoconductor units (order Printer Maintenance Kit Type 7100A).
I do not know of any Replace CPU error messages. I hope this helps.
When I try to print,
The unit may have a paper jam or stuck object inside, if you
have experience a paper jam error before, check the printer for any
object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
PCU Replacement
You are more right than you know, the reason for the kit is for the reasons you said. When you change the kit all 3 colors are new and thereby not 3 service calls and 1 upset customer.
The kit is far cheaper and keep any "good PCUs" in the original package.
The black PCU is the most important one. Buying the different maint. kits saves $$$ as opposed to peicemeal.
You can put one color PCU in at a time if you wish.
-Carl, please let me know if this helps.
My nasuatec dsc 435 displays sc 440-02.I don't know what to do
That code is color drum motor lock (cmy). 440-1 is for black. Pull each drum unit out and look at the drum surface if one is not turning good it will have toner all over it. Could be that the drum is full of waste toner, but usually it is a backed up waste toner auger system. If that machine uses a fuser oil the oil has leaked down into the waste toner auger system and clogged it up.
How to get borderless printing on a CL7100
Laser printers are unable to print all the way to the edges of the paper because of the excess toner dust that will fall off into the printer unit. The only way to get true full bleed laser prints is to use a larger paper size and then cut the edges off.
Doesn't go past warmup.
you need check:
1) there are two fuses in the fuser unit, big possible one of them broken. change fuse if you can, should be fixed.
2) if check (use meter) all fuse good, so the heat lamp damaged,
you may change it also can fix it,
fuser unit maybe expansive.
hope hep you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
Ricoh CL7100 - Toner Cartridge Error
Not one answer for this problem. It could be the tube going from toner cart to developer unit is clogged or kinked. It could be the dev unit. Get a toner vac and remove toner and black cap and spring and using the round hose end create seal and vac the tube. The part that goes into the toner cart has hole on the very end, it might have broke off (look at another color to verify). The worst case is the toner attraction pump has failed. One fix is shake the toner and reinstall.
I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
- Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
- Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
- Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
- Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
- Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
- Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
- Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
- Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
- Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
