20 Most Recent
Epson Stylus Photo® R2400 InkJet Printer Questions & Answers
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
I hv nt used my print since long time n now when i
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Canon printer ip1000 blinks red and green
Depress power button while plugging the canon pixma ip1000. When you
depress the power button, the printer can be used even if the in waste
absorber hasn't been replaced.
EPSON STYLUS RX 520 HAS AN ERROR E-91
The error E-91 on an Epson Stylus RX 520 indicates a communication problem between the printer and the cartridge. Here are some steps you can try to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Remove all the ink cartridges and check for any damage or leaks. Replace any damaged or leaking cartridges.
- Clean the metal contacts on the ink cartridges and inside the printer with a soft, lint-free cloth. Make sure they are completely dry before reinserting the cartridges.
- Reinstall the ink cartridges and make sure they are properly seated.
- Turn on the printer and see if the error message still appears.
If the error message persists, try resetting the printer by following these steps:
- Hold down the "Stop" and "B&W" buttons while plugging in the power cord.
- Keep holding the buttons until the printer starts to initialize.
- Release the buttons and wait for the printer to finish initializing.
- Try printing again to see if the error message is resolved.
If none of these steps work, there may be a hardware issue with the printer and it may need to be serviced by a professional technician.
HOW TO RESET THE COUNTER ON MY EPSON STYLUS SX415
Please attempt to factory reset your printer in order to reset the counter. If you don't know how to do this, please check the table of contents in your device's manual: https://www.manualslib.com/products/Epson-Stylus-Sx415-4234082.html . Thank you.
