20 Most Recent
Systemax Venture PC Desktop Questions & Answers
No power when you press power button no response
The Power Supply could be bad. The Power Switch could be bad. The Motherboard could be bad. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. At least you may be able to salvage your data.
How do I completely wipe a syx-65Im03
Using your disk with the new OS on it; boot the PC using that disk, when you're going through the initial setup steps, you have the option to format the drive. Formatting the drive will wipe the hard drive clean and let you start over fresh.
Factory restore
if you are running windows7 you can use the backup tool in windows to make the image but remember to make a boot disc this backs up your registry and you will need it to re install your windows image.
DX38BT motherboard wirer hook up.
http://www.intel.com/support/motherboards/desktop/dx38bt/sb/CS-028327.htmClick on the blue - English Product Guide [ PDF ]After you click on the above file name it may take up to 30 seconds, before the first page comes up.Connecting to the Internal HeadersPage 50 for the PDF file page number. Figure 27. Internal HeadersThe front of your computer is the Front panel. The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.Item I in Figure 27.Detailed connections on Page 54.For additional questions please post in a Comment.Regards,joecoolvette
How do I update computer bios
Hiyou do not need to update the bios of your computer (systemax desktop pc ) because the current version of your bios is still up to date. If you are having a problem and you want your computer bios default all you need to do is to remove the cmos battery for 1 minute just to be sure because the standard wait time is only 30 sec. put it back after 1 minute. automatically the bios will be back to default settings
Computer wont boot completely up missing or corrupt files
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
Missing wndows/system32\config\system
You need to reinstall windows. You could try the check disk utility and see if it fixes it.To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /rCheck disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine. If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
