20 Most Recent Dell Dimension 4600 PC Desktop Questions & Answers
IBM Netvista A30 8315-61U what does IBM have to do with DELL?
huh?
that is now Lenova , IBM sold PCs div, to Lenova long ago.
so ill move you to lenovo
my guess the post should read
old Pentium 4 PC from Lenovo per above
I can not install and OS
NO OS stated, windows sure... but...
NO version OS stated XP, vista,w7,8,8,1.w10
no media you are using to install it.
the cure is easy , re-Install windows fresh
all data and your apps will be gone, we backup first.
if that fails the HDD is bad, run HDD test.s
run crystaldiskinfo on it if smart param, C6 is wrong, the drive is toasted.
Dell Dimension... | Answered on Jun 01, 2018
Hi sir/madam
Have u tried with Reinstalling powerdvd,windvd or nero only if it is winxp operating system.
Dell Dimension... | Answered on Sep 21, 2017
you may have a stuck key on the keyboard. I hope thats all it is as could be HDD died or motherboard
Dell Dimension... | Answered on Mar 24, 2016
Im not sure if you are asking for the E310 drivers or the 4600c drivers, so I'm sending you the link to download drivers for both the systems.
http://tinyurl.com/2jpgqs (Thats for E310)
http://tinyurl.com/5jzwtd (Thats for 4600c)
All the best fixing your system
Mandeep
Dell Dimension... | Answered on Dec 14, 2015
Hi this is Alex Walker I am expert to help you for your issue call me +1(404)981-1535
Dell Dimension... | Answered on Nov 24, 2015
have you checked out if they work in safe mode?
if they work in safe mood means they are working
which keyboard mouse are you using usb? ps2? or wireless?
Dell Dimension... | Answered on Nov 06, 2015
Hello, the only other way is toget a password cracker.Go here for password help.
Ophcrack
Dell Dimension... | Answered on Nov 01, 2015
Forgot your Windows XP password? Don't worry about that. I have troubled the same thing before. I searched from internet and solved the problem. Now i want to share with you and hope it will really help.
Solution 1: If you have owned another available admin password, it can work. Just log on your PC->Click "Start"button->Control Panel->Add or remove user account->Select the account you want to reset->Change or Remove the password. Then the password will be reset.
Solution 2: You can use one of the password recovery software tool to reset the forgotten password. Here, i would like to introduce you one of them, which i have applied. It is really a good hand. That is Windows Password Reset . The process is following.
Step 1: Download the Windows Password Reset Deluxe from http://www.windowspasswordreset.net and burn a erasable CD
Step 2: Boot the CD into the ISO image which is provided by Windows Password Reset Deluxe
Step 3:BIOS settings
Step 4:Recover the Windows XP admin password.
It is an easy-to-use way to reset windows password.
You can have a try.
Dell Dimension... | Answered on Mar 16, 2015
Hi stefyboy - Below is a link where you can download your driver. After you get to the page just make sure it says Windows XP as the operating system. Then scroll down and click on the + next to where it says network. You want the intel 10/100 driver. I've included a few a ways to install it. If your kinda new to this the easiest is the download to desktop method and just remember where it unzipped it to, you can always move it to a driver directory where you can keep all your drivers for the future.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be glad to assist you further. Thanks.
Jeff
Hard Drive Installation (via WinZip) with HTML Pop-Up Window for R67150.EXE
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save this program to
disk (Windows XP users, click Save) and click OK. The Save In: window
appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
name icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled R67150.EXE.
The Self-Extractor window appears.
2.Click OK or Continue.
The Self-Extracting Driver Installation window appears and prompts to
extract files to C:\DELL\DRIVERS\R67150.
3.Leave all of the default settings and click Unzip or OK. If the directory doesn't exist, you'll be prompted to create one. Click Yes. A Self Extractor window appears and indicates C:\DELL\DRIVERS\R67150 files were
extracted.
4.Click OK.
Follow the on-screen installation instructions in the window.
HTML Pop-Up With Install Now Button
1.The Dell Software Installation Documentation window appears.
2.Click the Install Now button. A File Download window appears.
3.Click Run this program from its current location and click OK.
The Security Warning window appears.
4.Click Yes. The InstallShield Wizard window appears.
5.Follow the on-screen instructions.
Dell Dimension... | Answered on Mar 06, 2015
Try this first - open up the BIOS part of the system. To do this, shut the computer off; wait at least 10 seconds; turn the computer back on and then press F2 when the Dell logo appears. Press continually until the message Entering Setup appears. In the Boot Order section, remove the CD/DVD drive from the boot order by clicking on Disable from the drop-down menu. If this doesn't fix it, please resubmit your question
Dell Dimension... | Answered on Feb 20, 2015
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Dell Dimension... | Answered on Feb 05, 2015
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Dell Dimension... | Answered on Feb 04, 2015
Is it power on (BIOS password or Windows Password?
Clearing Forgotten BIOS Passwords (from Owners Manual Page 109)
CAUTION: To guard against electrical shock, always unplug your computer from
the electrical outlet before opening the cover.
Shut down the computer through the
Start
menu (see page 27).
NOTICE:
To disconnect a network cable, first unplug the cable from your computer and then
unplug it from the network wall jack.
Turn off any attached devices and disconnect them from their electrical outlets.
Disconnect the computer power cable from the wall outlet, and then press the power
button to ground the system board.
Remove the computer cover (see page 74).
5
Locate the 3-pin password jumper (see page 77) on the system board, and then attach
the jumper to both pins.
When you receive your computer, the jumper is attached to only one pin.
6
Replace the computer cover (see page 99).
NOTICE:
To connect a network cable, first plug the cable into the network wall jack and then
plug it into the computer.
7
Connect your computer and devices to electrical outlets, and then turn them on.
8
If you are prompted to press <F1> to continue, press <F1>.
9
After the Microsoft Windows desktop appears on your computer, shut down the
Start
menu (see page 27).
NOTICE:
10
11
12
13
Remove the password jumper.
Attach the jumper to only one pin so that you do not lose it.
Dell Dimension... | Answered on Dec 25, 2014
Remove the hard drive and destroy it.
Dell Dimension... | Answered on Oct 14, 2014
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
Dell Dimension... | Answered on Aug 18, 2014
You probably need to install a newer version of DirectX software from Microsoft.
You appear to have DirectX version 8 installed at the moment, which is an old version.Download this web installer file, then run the file (double-click) and DirectX will download & install automatically.
http://www.microsoft.com/en-us/download/details.aspx?id=35
Download and Install DirectX9 End User Runtime Install DirectX DX9
Dell Dimension... | Answered on Aug 07, 2014
http://www.dell.com/support/home/us/en/19/product-support/product/dimension-4600/drivers
Dell Dimension... | Answered on Jul 22, 2014
try to run with chkdsk command and if it is fail kindly replace the disk.
Dell Dimension... | Answered on Jul 17, 2014
Dell Dimension 4600 PC Desktop Logo
1,245 questions posted
Ekse
Alun Cox
Thomas F. Schneider
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
compatible printers dimension 4600
  • Computers & Internet
