20 Most Recent Dell OptiPlex GX270 PC Desktop Questions & Answers
Strike f1 retry boot f2
Question posted in 2014, almost 5 years back, laptop by this time seems to be abandoned or scrapped? and if still searching only solution is to change the Hard Disk Drive
3/10/2019 12:49:41 PM • Dell OptiPlex... • Answered on Mar 10, 2019
Dell optiplex 790 driver for windows 7
What driver do you need ?
11/3/2018 1:52:18 PM • Dell OptiPlex... • Answered on Nov 03, 2018
2answers
My computer is Dell OptiPlex
Just download sound drivers and then install. This will sort your problem.
10/9/2018 12:16:44 AM • Dell OptiPlex... • Answered on Oct 09, 2018
Gx270 Willnot boot in to winodws xp
sounds luike you might have had a virise and its wiped somonthing it souldint have out you can save your things in safe mode and re do the os (reinstall windows ) if you recantly conected hardware to then unistall and disonect it then retry it
4/28/2018 4:01:50 PM • Dell OptiPlex... • Answered on Apr 28, 2018
My USB ports in Optiplex
Then the motherboard is defective
7/8/2017 10:03:29 PM • Dell OptiPlex... • Answered on Jul 08, 2017
How to replace battery in GX 270
Look on the Dell web site for the GX270 'service manual' - if no luck, then I suggest you post this question to the DELL WEB SITE HELP forums ..
3/30/2016 10:05:20 AM • Dell OptiPlex... • Answered on Mar 30, 2016
2answers
When booting my dell optiplex dimension 270 i get an alert message of checkpoint [krst]
Try running the Check Disk Utility.To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /rCheck disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine. If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
2/7/2016 1:51:21 AM • Dell OptiPlex... • Answered on Feb 07, 2016
3answers
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe OR %Windir%\System32\rstrui.exe Other Thoughts -------------- If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
1/29/2016 10:55:33 AM • Dell OptiPlex... • Answered on Jan 29, 2016
4answers
Attemped to find a Video Controller Friver(VGA
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R79733&SystemID=PLX_PNT_CEL_GX270&servicetag=&os=WW1&osl=en&deviceid=6294&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=6&fileid=104486
There is a couple other choices to choose from, but this should get the job done. Just copy and paste the link above in your browser window. Download the driver and follow instructions.
7/26/2015 8:27:10 PM • Dell OptiPlex... • Answered on Jul 26, 2015
3answers
Comp won't power on
Hi KlubeT,
I would suggest replacing the PSU (Power Supply Unit).
Gerry
5/19/2015 12:25:34 AM • Dell OptiPlex... • Answered on May 19, 2015
2answers
Dell GX270 does not recognise HDD after CMOS battery failure
It Seems to me IDE HDD In your BIOS should be set to on.
5/9/2015 11:19:49 PM • Dell OptiPlex... • Answered on May 09, 2015
How to fix emem problem
Hello babu.. what is emem..??\
11/14/2014 5:51:26 AM • Dell OptiPlex... • Answered on Nov 14, 2014
3answers
O Windows cannot be installed on this computer with the current system BIOS version. Contact your computer manufacturer for a BIOS update, install the update, and then start Windows installation again
je veux que mon pc allume bien. il est divise en 6 parti a cause de mon bios qui ma demander de upgrade, je ne sais pas comment pour le faire.
10/21/2014 9:01:46 PM • Dell OptiPlex... • Answered on Oct 21, 2014
Dell GX270 has D amber light
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
10/9/2014 10:22:41 PM • Dell OptiPlex... • Answered on Oct 09, 2014
My pc dell gx 270 board light is orange and no show disply monitor
Might need to Change the Motherboard
9/24/2014 12:59:44 PM • Dell OptiPlex... • Answered on Sep 24, 2014
How to reset the case intrusion warning
Resetting the Chassis Intrusion Detector
  1. Enter system setup by pressing <F2> during the computer's start-up.
  1. Under the System Security tab, reset the Chassis Intrusion option by pressing the left- or right-arrow key to select Reset. Change the setting to Enabled, Enabled-Silent, or Disabled.
8/13/2014 5:30:06 AM • Dell OptiPlex... • Answered on Aug 13, 2014
Driver for communication controler
click here to go to Dells website to download communication driver Driver Details Dell US its the communication driver
8/6/2014 4:24:10 PM • Dell OptiPlex... • Answered on Aug 06, 2014
My Optiplex GX270 is not booting up past Windows log on page, it has a pop up WININET.dll was not found. Re imstalling the application. may fix this problem. What if anything can I do to salvage thi
It has a Windows file missing (and usually many others). The most common reason is hard disk failure. When Windows files just start to disappear, it is usually a sign that the drive is dying. It can also be caused by virus activity, but it is rare if you have a good antivirus package. It would pay to get the hard disk checked.
7/3/2014 7:53:12 AM • Dell OptiPlex... • Answered on Jul 03, 2014
2answers
Alkaline phosphate diagnotic signicances
The problem might be related to a virus on the desktop computer. Try going in to safe mode by pressing F8 on Start up using network connections. Go on to the Web and download from Cnet.com a program called Malware byte. Run Maleware byte, after every has been scan look for another website to download the dll http://www.geekstogo.com/forum/topic/54300-wininetdll/
6/16/2014 7:04:24 AM • Dell OptiPlex... • Answered on Jun 16, 2014
Dell OptiPlex GX270 PC Desktop Logo
573 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
need resore without disc promts use in
  • Computers & Internet
