You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup. If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date. Save, Exit and re-boot and everything should then work. This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged. During the boot process you will see on the screen a certain key to press to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date. hope this helps you
System restore will not do what your asking.
However there is a way but you will need a Installation cd Assume you have Windows XP
Then you need to borrow or buy a Windows XP Home Edition or Pro
You can buy one used from Ebay.
There are two options !.Repair install this will save all files/data on your hard drive.
Follow these instructions to Repair install.
Boot the computer using the XP CD.
You may need to change the boot order in the system BIOS so the CD boots before the hard drive.
Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft Windows XP to run on your computer:
To setup Windows XP now, press ENTER.To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.Press Enter to start the Windows Setup. Do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console).
I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations. Select the XP installation you want to repair from the list and press R to start the repair.
If Repair is not one of the options, END setup.
After the reboot
Setup will copy the necessary files to the hard drive and reboot.
Do not press any key to boot from CD when the message appears.
Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.2. If you want to do a clean install that will completely wipe your hard drive clean then follow the instructions from this site http://www.winsupersite.com/showcase/win...
You will then need to reload all Microsoft Windows Updates and find all other drivers and software from http://uk.computers.toshiba-europe.com/c...
Then wham bam you should be back in business.
hope this helps
12 questions posted
49 Questions
30 Questions
10 Questions
7 Questions
4 Questions
