20 Most Recent Gateway GT5034 PC Desktop Questions & Answers
Everytime i plug my iphone into my computer it
I would try another usb port if you have not yet. The other issue that is possible is that the computers power supply is "on edge" and the bit of extra power from the usb, is causing it to shut down. Actually, pretty common on the GT5034, I would take it to a shop and see if they will test the power supply free. Please leave a positive rating.
10/20/2010 3:08:52 AM • Gateway GT5034... • Answered on Oct 20, 2010
5answers
When I plug in my Iphone computer shuts down
Make sure you've got the latest version of Itunes installed, if you have Itunes on your PC at all.
Try changing your drive letters: Click Start, click Control Panel, and then click Performance and Maintenance. Make sure you are in Category View. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane. Right-click the drive, the partition and then click Change Drive Letter and Paths. Click Change. Click Assign the following drive letter if it is not already selected, click the drive letter that you want to use, and then click OK. Click Yes when you are prompted to confirm the drive letter change.
Try the IPhone now.
5/12/2010 5:28:09 PM • Gateway GT5034... • Answered on May 12, 2010
2answers
My new iPhone 3GS shuts down my computer when I plug it in
Hi I had the same problem, for a few days the new Iphone worked fine then started to appear as digital picture divice then just shut my Laptop down as soon as i plugged it in. I contacted Apple who were very helpfull and sent me 4 mails with advice. The one that worked for me was ...........
If you have anything running on your pc/Laptop with Logitech driver it conflicts with the apple drivers. I had a built in webcam on Laptop and when I typed Logitech in the search on start menu found it was run by that driver. I uninstalled it and deleted all the relavent files plugged Iphone in and no more problems except I now dont have a webcam but I thought small price to pay.
I hope this Helps
Best wishes
Andy
1/4/2010 10:23:33 PM • Gateway GT5034... • Answered on Jan 04, 2010
My new iPhone 3GS hsuts down my computer when I plug it in
ohh...if it is appear a blue screen,....thats what they call a PHANTOM PROBLEM...
you must be install first the iPHOne before you connect it to the PC
10/23/2009 6:31:15 AM • Gateway GT5034... • Answered on Oct 23, 2009
Help me
You are having a hardware conflict.....do you have your iphone software installed.......I know that without it on some pc's theres issues
9/27/2009 8:13:49 PM • Gateway GT5034... • Answered on Sep 27, 2009
Same problem
OK, here you go. (perhaps if you posted a question rather than a statement?)
7/31/2009 11:27:05 AM • Gateway GT5034... • Answered on Jul 31, 2009
3answers
My laptop shuts down when i connect my new iPhone 3G
does your computer have a webcam? if it does, the computer is restarting itself because it identifies two conflicting cameras - one from your computer, the other from your iphone. what you can do is either 1)update your camera drive, 2)update your computer drive or 3)use a computer that does not have a webcam connected to it. hope this helped!
also, if you're using windows vista, this link will help you: http://support.apple.com/kb/TS2280?viewlocale=en_US
7/31/2009 6:12:40 AM • Gateway GT5034... • Answered on Jul 31, 2009
Computer shuts down when I plug in my iphone
if the pc its shutting down when ya plug that device ..this just means that it has some settings against this kinda devices or windows do not recognize it well and it sees it like pest ...and shuts down the pc as protection .....its eiter doesnt have a USB 2.0 port ..or its just a firewall kinda problem ...try it on other pc-s and see if the problem persist there ...if not its from your machine ..if other computers shuts down too ..its from the "bloody " I phone ...might have something in it ..a bug ..or a software protection ...
7/6/2009 7:24:42 AM • Gateway GT5034... • Answered on Jul 06, 2009
GT5034 has power, blue light on power button, no
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at [email protected] or if you got anymore questions.
6/29/2009 3:25:18 AM • Gateway GT5034... • Answered on Jun 29, 2009
Windows xp shuts down when i connect iphone to try dwnload itunes
your pc has a virus
3/10/2009 10:34:58 PM • Gateway GT5034... • Answered on Mar 10, 2009
I have the application SuperSU the free edition on my phone and everytime I try to use it to root my phone forwards me to an address on Chrome the simply says 502 bad gateway
you can use kingroot to root your phone. and some root apps might harm yor os i suggest you not to root your phone
3/1/2024 4:28:21 PM • Gateway... • Answered on Mar 01, 2024
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor. The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port. I hope this helps. Cindy Wells
1/18/2024 10:32:24 PM • Gateway... • Answered on Jan 18, 2024
I have a gateway Zx4931 and the power button is not working. Do I need to replace the power button or can I reconnect the wires?
Re connecting the wires may work without issues.
12/26/2023 5:46:39 PM • Gateway... • Answered on Dec 26, 2023
Do i need a driver for old gateway gmax2000 speakers connected to an old acer-based home built pc my nephew gave me?
No you don't need a driver. These are very plain powered speakers that come with a mains adapter and a lead with a 3.5mm stereo jack at both ends. Plug one in the speaker and the other into the headphone jack on the front or the speaker socket on the back which will either be a socket on the motherboard, or if your son put a sound card in the computer, it will be in a sound card. If it doesn't play straight away, go into Settings - Audio and make sure the sound card or the On-Board Audio is enabled. This shows the cable https://picclick.com/Vintage-Gateway-2000-ACS41-Altec-Lansing-Multimedia-Computer-314990339798.html#&gid=1&pid=1 More here https://www.google.com/search?q=gateway+gmax2000+speakers ..
11/29/2023 12:20:06 AM • Gateway... • Answered on Nov 29, 2023
WATTS REQUIRED FOR GATEWAY LAPTOP NV55C
110 watts for the power supply.
11/21/2023 1:16:48 AM • Gateway... • Answered on Nov 21, 2023
Wiring diagram for LX6200-01
10/30/2023 11:58:58 PM • Gateway... • Answered on Oct 30, 2023
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do. First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button. Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button. Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation. I hope this helps!
3/14/2023 5:41:18 PM • Gateway... • Answered on Mar 14, 2023
I have a Gateway Laptop that on startup only goes to the configuration screen. It won't boot Windows at all
They deleted the Operating System by deleting their own stuff Docs, images, Saved Links etc. and also everything in Windows System probably in spite. You need to reload the operating system (Win 11) from fresh. Charge them from their final pay check, or ask IT to do it.
3/1/2023 1:19:14 AM • Gateway... • Answered on Mar 01, 2023
2answers
Gateway / Packard Bell EASYNOTE MS2291 Laptop will not start.
Question edited for a lot more clarity, FULL 'make, model (what it is)'. Question moved from 'Power Computers'. Connect a computer monitor to the port on the back. When I Google the model number the first thing that shows is Replacement LCD Screens for it which leads me to believe there is an issue with them. There is three parts to the display, the video card section, the exciter module and the screen itself. It needs correct diagnosis, or buy a new one now you have reset it clean, if that is what you mean by 'hard restart'? You might mean 'hard boot', power off and back on without proper shutdown. That is bad for the OS. https://www.google.com/search?q=Model+MS2291 Keyboard shortcuts for shutdown
How to Shut Down or Sleep Windows 10/11 With a Keyboard ...
https://www.makeuseof.com > Windows 1. Use the Power User Menu Shortcut · Press U again to shut down Windows. · Hit the R key to restart. · Press S to put Windows to sleep. · Use H to hibernate. · Hit ... Sleep Mode Issues · ‎Establish a hotkey · ‎Guide to hibernation on.....
2/26/2023 8:34:30 PM • Gateway... • Answered on Feb 26, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
  1. Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
  2. Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
  3. Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
  4. Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
  5. Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM • Gateway... • Answered on Feb 26, 2023
Gateway GT5034 PC Desktop Logo
13 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
when plug in iphone computer shuts down
  • Computers & Internet
