20 Most Recent Gaggia Titanium Espresso Machine Questions & Answers
3answers
Brew unit won't go back into machine N symble is lined up correctly but the cog inside machine doesn't line up
Machine is probably not in the fully "at rest" position. See if you can get the tray in without any other parts on it. Sometimes the waste grounds bin will foul on the mechanism if brewing unit has not stopped in the correct position. Once the bare tray is in and activating the switch the machine will realign itself when turned on.
12/22/2022 2:33:01 AM • Gaggia Titanium... • Answered on Dec 22, 2022
2answers
My gaggia titanium says fill water tank, i fill it
tank sensor water level on bottom, check it.
2/13/2022 3:41:20 PM • Gaggia Titanium... • Answered on Feb 13, 2022
I have bought a new board for my gaggia titanium expesso machine. best way to replace the board?
I have the same machine I need to replace the motherboard. Did you get an answer on how to replace it? Also, what company did you use to get a new one? Thank you, I am in the UK
11/16/2021 12:56:21 PM • Gaggia Titanium... • Answered on Nov 16, 2021
Replace mother board on gaggia titanium
To replace the mother board, the top cover of the machine has to be removed. I can email the illustrated steps for taking the top cover off as an attachment. However I am curious to know the following: 1- why this is the only expensive option to fix the machine 2- Is the person who diagnosed replacement of this part qualified to do so. 3- Has the part been taken out of the machine to inspect any visible damage on it like a burn mark or shorted circuits. 4- Is the brew drive system that operates the Brew group is functioning or not. 5- How long the machine was used. 6- Whether the machine was descaled at all and the descaling product used was authentic product (CleanCaf, Brew Rite, Pulycaff or similar product which are sold as descalers but the same are not). 7- I do not support, recommend or sell parts unless I know it is the correct solution to fix the machine.. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
11/16/2021 12:52:17 PM • Gaggia Titanium... • Answered on Nov 16, 2021
Gaggia Titanium blocks on display screen
The main board has failed.
Sorry no quick fix for that one
11/16/2021 12:32:26 PM • Gaggia Titanium... • Answered on Nov 16, 2021
2answers
Gaggia brera, coffee beans compartment is full of
I have the same problem. Not a solution, but you can still take the ground beans and brew coffee, using the pre-ground compartment.
10/5/2021 2:54:43 PM • Gaggia Titanium... • Answered on Oct 05, 2021
3answers
Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
5/12/2021 12:39:41 PM • Gaggia Titanium... • Answered on May 12, 2021
2answers
Screen says brewunit blocked. Brewunit seems clear
Hi If you remove the brew unit and put everything back with out it the brew unit. Turn th machine on and see if it will cycle? Open the door and look in the back where the brew unit was. There is a cog in the back with teeth. There are 2 large teeth, and they should be at the 10 and 12:00 position roughly. If they are anywhere else you have a broken drive and need to get the gears replaced. If they are in the correct position check the front of the brew unit where the circles are. There are 2 diamonds and they should be pointing at each other. if they are not you need to bring them together with the key tool. Insert it into the center of the circles and turn until they line up, then put back into the machine, and see if it will work. If it still doesn't you have a bad board.
11/3/2019 4:11:48 PM • Gaggia Titanium... • Answered on Nov 03, 2019
3answers
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
11/3/2019 4:11:39 PM • Gaggia Titanium... • Answered on Nov 03, 2019
3answers
Ground coffee will not dispense
The beans are hanging up in the hopper and not falling down into the grinder...... wiggle it, give the beans a push, or go to a bean that is not so sticky....
2/1/2019 7:56:26 AM • Gaggia Titanium... • Answered on Feb 01, 2019
Gaggia Titantium says dregdrawer missing
Look at the sensor for the door to see if there is any broken plastic pieces or perhaps the sensor has come loose and just needs adjusting.
2/13/2018 12:51:20 AM • Gaggia Titanium... • Answered on Feb 13, 2018
2answers
Gaggia titanium machine, is Ventilate problem connected to leak??
the steam valve is most likly plugged with sacale or such have you decaled the machine latly may want to start there
11/17/2017 2:02:49 AM • Gaggia Titanium... • Answered on Nov 17, 2017
0answers
Gaggia Titanium Espresso Machine Logo
706 questions posted
Top Gaggia Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Gaggia Coffee Makers & Espresso...
  • Gaggia Coffee Makers & Espresso...
Most Popular Question
fill watertank message appears even
  • Coffee Makers & Espresso Machines
