20 Most Recent
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Questions & Answers
Cannot delete files from transcend storejet 2.5 160GB
Is there a physical lock on the device that needs to be switched?
Here are a few things to consider:
- Only have one Explorer window open.
- Have no other programs running that might be accessing the files.
- Right-click the file, click Properties, and see if the write protection is on.
10/15/2017 3:59:50 PM •
Transcend...
Answered
on Oct 15, 2017
I have a transcend 320
Use the following command in command prompt and your problem will be gone for sure (it will not delete any content) :-
attrib -r -s -h g:\* /s /d
Note:- (replace "g" letter in the above command by your transcend's drive letter)
To open command prompt press WindowKey+R and write cmd in the box and press enter. Then write the above command on the command prompt window and press enter.
---->Attrib command is use to change the Attributes of file/folder to showup(unhide) in windows. use attrib/? at command prompt for help.
1/1/2014 10:31:06 PM •
Transcend...
Answered
on Jan 01, 2014
I have bought a 640GB
You can retrieve your data with data recovery program.I have succeed to recover data from crashed hard drive with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash.Download a trial version and scan your hard drive for free to check out whether your files can be recovered.Luck!
http://www.any-data-recovery.com/index.htm
12/25/2013 2:59:51 AM •
Transcend...
Answered
on Dec 25, 2013
Describe your Transcend StoreJet 2.5
I have Problem with the Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive.
I didnot register it on line.in time i was presented this nice device..
because it was working ok .when i just connect it to LapTop.
NOW..After almost 2 years .it s became not RECOGNISED BY MY pc.
And i cant find any driver for it.I have all my important documents in Transcend.
WHat can i do.friends.. Any help?
Please help old Lady.
Thanks if responded.
[email protected] is my mail and this is banner i see.
5/1/2013 12:33:52 PM •
Transcend...
Answered
on May 01, 2013
Storejet problem
Good day!
1. Go to my computer and right click then click manage, go to disk management and see if your external harddisk is showed.If showed,then you can see the options there to manipulate your harddisk, either you format it or repartition.
2. You can use also a disk manager software to fully control the function.
2/14/2013 10:45:36 AM •
Transcend...
Answered
on Feb 14, 2013
Lost of driver cd of storjet 320 gb
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
2/6/2013 12:59:03 PM •
Transcend...
Answered
on Feb 06, 2013
I was using one of
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech
data recovery program to recover your files.
http://www.asoftech.com/adr/
1/20/2013 1:41:48 PM •
Transcend...
Answered
on Jan 20, 2013
Adriver for Transcend StoreJet320GB for windows 7
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution note: it will find all of your outdated drivers This is a free driver solutions. This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. Hope this helps
12/21/2012 3:43:17 PM •
Transcend...
Answered
on Dec 21, 2012
Need to download driver use transcend JF V33 with
i dont think itll work on 98 ive tried it many times for friends and windows 98 because of no support will nor run the sticks i tried 4 differnt sticks and none would work and i have the cds for them,But go to the manufactures site of the usb find [drivers downloads] and select your model and down load it maybe itll work out fine for you.
11/13/2012 7:13:01 PM •
Transcend...
Answered
on Nov 13, 2012
I'm using transcent storejet 25M.i
Hi, Thanks for using fixya.
First unplug any other USB devices / hubs from your computer. Reboot the computer with the transcent in a usb port. Check to see if you can use it when it boots back up.
If not :
1. Right click on My Computer choose manage. On the left side make sure storage is expanded double click disk management on the left upper side see if transcent is listed.
2. If it is on the lower part find your transcent right click on it choose change drive letter and paths. Click on change, you will see a drop down arrow click that choose the first available letter, Now click on change. Open My Computer see if it is now listed.
3. Reboot your computer when it comes back,open My Computer see if it is now listed.
If not:
I will take a guess and sday your device maybe defective meaning no way to recover your files.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
7/23/2012 10:49:09 PM •
Transcend...
Answered
on Jul 23, 2012
