20 Most Recent Akai CTD-1390 TV Questions & Answers
Fault with the main power supply regulator section circuit.. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Akai CTD-1390 TV | Answered on Nov 18, 2014
Video output section circuit [CRT base card]; fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Akai CTD-1390 TV | Answered on Nov 15, 2014
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Akai CTD-1390 TV | Answered on Jun 08, 2013
Sounds like you  accidentally "set" the parental lock while you were sleeping.
Try this trick: (may or may not work)
aim the remote at the TV "IR sensor", hold down "display button" on the remote for 10 seconds to erase or clear the password.
"IF" this works go into the menu and "TURN OFF" parental control.
a loose interfaced connection could caused this problem try to clean the connector and make another test attemp
Akai CTD-1390 TV | Answered on Jul 16, 2011
You can push the button on the set, or buy a universal remote.
Akai CTD-1390 TV | Answered on Apr 04, 2011
Try fixing your remote control
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Akai CTD-1390 TV | Answered on Jun 25, 2010
my tv akai ctd1390 is lock i dont have the remote now
what can i do ? to unlock it
Akai CTD-1390 TV | Answered on Jun 08, 2010
al tv esta bloquea y no recuerdo la clave como hago
Akai CTD-1390 TV | Answered on Jan 31, 2009
All URCs do not handle all functions of a particular TV. Try a different URC that has volume control.
Akai Televison &... | Answered on Dec 25, 2019
I show 002 but use code search as there may be others.
Akai Televison &... | Answered on Oct 26, 2019
Try restoring it to factory settings. I found these instructions and hopefully they'll help you to disable the channel lock problem you have -
How to Find the Reset Button on an Akai TV Techwalla com
Akai Televison &... | Answered on Oct 25, 2019
Akai CTD-1390 TV Logo
20 questions posted
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
tv child lock mode not know
  • Televison & Video
