20 Most Recent
Insignia NS-13CTV Questions & Answers
8 yr old mitsubishi tv black with static then will finally turnon
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase "
my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
4/4/2017 3:13:26 PM •
Insignia...
Answered
on Apr 04, 2017
Try to add channels
use automativ searvh feature and let it till stop in every chanell then u press store button?
12/9/2011 5:16:16 AM •
Insignia...
Answered
on Dec 09, 2011
Cant program a channel into
It's my understanding that you're trying to get your DISH remote programmed to your TV, rachellebria. The following are the steps you can take to get that accomplished:
- Turn the Television On
- Press and Hold the TV Power button for three seconds until the LED flashes
- Enter the three-digit code using the buttons on the number pad.
- Press OK
The LED will flash three times.
- Test functionality with the TV
- Return to Step 2 if the remote is not able to turn the TV On/Off, change the
volume and mute the television.
Hope that helps!
3/2/2011 7:23:15 PM •
Insignia...
Answered
on Mar 02, 2011
Need instruction booklet for this tv
The command you seek is in the remote. You will have to experiment as to what menu item will separate an over the air signal to cable. It should say on the menu screen and it will direct you....seek and ye shall find.
9/12/2009 6:20:08 AM •
Insignia...
Answered
on Sep 12, 2009
Memorex MLT 1912 randomly changes channels and powers on/off
Repairing that TV out of warranty--out of your pocket--would not be worth the money. The labor alone will be a minimum of $75 to $100 not including any parts. With 32" LCDs going for under $400 at www.walmart.com, it isn't worth spending $150 to $250 fixing a used TV that will still be out of warranty once it's repaired. Also, the last time I was in Wal-Mart, they had a 27" tube TV for $188.00.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
7/18/2009 8:28:25 PM •
Insignia...
Answered
on Jul 18, 2009
Can't get cpmonents to work
I would try to change to a different input on your T.V. with the remote or with the channel button on the T.V.
5/30/2009 8:12:41 AM •
Insignia...
Answered
on May 30, 2009
