20 Most Recent
Nextar MA833A-BL MP3 Player Questions & Answers
FOLDERS WONT SHOW UP ON PC.
It appears you have selected to play when inserted.
Go to my computer, right click your device, select open as a portable device. (so it can see the folder)
When the window on your desk opens select open folder.
It should open in this format from now on and you should be able to see the contents of your device.
However you failed to mention what operating system you are running so these instructions may not apply.
Also; You may have to pull those files/songs out of the folder and install them directly to your device (just as the new material is installed) because no auto-play can read a folder. This is probably is the best solution if you want the music to start playing when plugged in...
Removing music from mp3
What i do on this problem is by delleting it in the folder of MP3 itself. I copy the music in a folder which is in my computer as back-up for futire use before i delette.
My usb mp3 player
my mp3 player won't turn on either. it was just bought and i added songs but it can not turn on.
Nextar mp3
you cant put music from iTunes onto your mp3.. it doesnt work that way, you have to rip songs from a CD you already own onto your computer and then you must go into your media on your computer to do this. and then there should be a file labled the title of what the album was called.... you also need to go and click the start icon on the bottom left hand part of your screen, click the icon that says: 'My Computer' , then click on the icon that says CENSO (E;) , go to your media page and click the file of songs you wish to add to your mp3 and drag it to the mini bar at the bottom of the screen that has your mp3 info (songs and stuff, FYI dont delet anything from there that is NOT a song), your mp3 info page should pop up and then last but not least, drop your song file in any BLANK space.
Good luck and i hope i helped you :D
Crash
Have you tried to scan your MP3 with anti-virus thru your computer? Maybe your MP3 pick-up a virus thru USB.If there is a virus, maybe your anti-virus can delette it.
Putting on songs
well lime wire and itunes arn't that great the way i put on songs is using a program called blubster then u save it as a play list in windows media player then it should work also if u have a voice button on ur mp3 check in there cause thats what mine did at first
Mp3 problem
probably YOUR son got water on it or dust something must have effected it ask him what happened has it dropped & then .......
{SORRY THE END OF THIS COMMENT HAS ISSUES COMING UP PLEASE RESTART THE INTERNET ENCASE }
Will not operate using battery
Even rechargeable batteries eventually die. Have you tried leaving it plugged into power for a long time, like at least overnight? As for a manual, you didn't list a make or model. Try a search for the make and model and include user manual in the search box.
