20 Most Recent Shure (LX287CC) Professional Microphone Questions & Answers
Radio Microphones.
See the following for repairs: http://shure.custhelp.com/app/answers/detail/a_id/4053
7/27/2014 2:54:02 AM • Shure (LX287CC)... • Answered on Jul 27, 2014
I have a Shure PG48
That's really hard to diagnose over email with this description. I suggest calling Shure Applications at 800-516-2525. They can help you troubleshoot and ask any questions that might help in determining the problem.
1/19/2011 8:42:06 PM • Shure (LX287CC)... • Answered on Jan 19, 2011
(LX287CC) Professional Microphone: We have a SM58 wireless... there is a plastic cove...
Call Shure Service at 800-516-2525. They can help you with instructions.
10/29/2010 2:41:27 PM • Shure (LX287CC)... • Answered on Oct 29, 2010
I have a Paso Series 5000 intergrated power
I suggest sending the mic to Shure for repairs. That will be cheaper than purchasing a new mic.
10/5/2010 3:04:27 PM • Shure (LX287CC)... • Answered on Oct 05, 2010
2answers
I have a 57abeta radio mic. Everything appears to
Please check if the gain in the microphone is open.
Ther's a little hole where you can adjust the gain.
Good luck,
Gerard
8/17/2010 2:15:26 PM • Shure (LX287CC)... • Answered on Aug 17, 2010
2answers
Where to buy a the swivel adapter for shure sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
8/17/2010 2:13:20 PM • Shure (LX287CC)... • Answered on Aug 17, 2010
2answers
Microphone cutting off
Ensure the battery in the mic is 100% - low batteries can cause all sorts of symptoms. I wouldn't recommend anything other than a well known brand of Alkaline battery and definatley not rechanrgables.
8/17/2010 2:09:37 PM • Shure (LX287CC)... • Answered on Aug 17, 2010
Hi, I have only the transmitter
Any Shure receiver that operates exactly at 173.800 MHz will work with your transmitter. These receivers have been discontinued for several years, so it will not be easy finding one on the exact frequency that you need.
8/6/2010 2:50:19 PM • Shure (LX287CC)... • Answered on Aug 06, 2010
2answers
I have a shure microflex mic condencer 150 the led
Try using a mixing console with phantom power ( + 48 ). A condenser mic needs 48 volts to operate. The led should light when the XLR microphone cable is connected to a console with phantom power.
7/15/2010 8:57:27 PM • Shure (LX287CC)... • Answered on Jul 15, 2010
Change a Shure Beta 87A LX2-ZZ VHF to UHF
That would be nearly impossible to do. However, you should be able to get a schematic from Shure Service at [email protected]
5/13/2010 8:56:38 PM • Shure (LX287CC)... • Answered on May 13, 2010
I have a well used shure pg58 that wont turn on.
It's hard to tell what might be causing the mic to not power on. It would be best to send the mic to Shure for repairs. Contact Shure Service.
5/7/2010 9:18:21 PM • Shure (LX287CC)... • Answered on May 07, 2010
I tried to open my Sure sm58 microphone to clean
To open the SM-58 you can unscrew the top of the body. I don't mean the grill.
Sometimes it's a hard job to open it.
Regards,
Gerard
3/31/2010 2:06:22 PM • Shure (LX287CC)... • Answered on Mar 31, 2010
My microphone has no sound
Your gain adjustment should be increased in the microphone or maybe the outputlevel from your receiver. If both doesn't solve your problem, maybe the element has a problem. You could turn of the grill and you will find the solderingjoints, just tip it with your finger. If you hear some hum, your element has a problem.
Regards,
Gerard
1/29/2010 10:02:45 PM • Shure (LX287CC)... • Answered on Jan 29, 2010
Battery connection on my Shure SM58
Hiya,
I know they could have come have come up with something a little more durable!!
What we used to do is put a piece of double side tape at the back (the thick 2mm spongy one) and then put paper or something over the front so the battery doesnt stick to it, battery then has alot more pressure on it. The tape sticks into the back of the mic. Its a bit stoneage, but worked pretty well.
Best of luck
7/16/2009 12:39:38 PM • Shure (LX287CC)... • Answered on Jul 16, 2009
Trying to open my Shure sm58 beta
About half way up the body you will see a seam. The body with the cartridge and wind screen separates from the bottom half of the body at that juncture. You have to unscrew one from the other. You will see wires that have to be unsoldered. Make note of where they were soldered and do the same thing for both the mike with the dead cartridge and the mike with the good cartridge. Swap straight across and you're done. Hope this helps.
5/30/2009 4:01:18 AM • Shure (LX287CC)... • Answered on May 30, 2009
Shure sm58 wireless mike, 9v battery connection flaky
Unscrew the wind screen and slide out inside component, be careful not to pull too hard and disconnect wiring. You may have to re-seal with a clear silicone gel afterwards.
12/28/2008 4:35:36 PM • Shure (LX287CC)... • Answered on Dec 28, 2008
SHURE BLX4R BATTERY LIGHT OFF AND WONT SYNC - HELP!
Hi, please attempt to factory reset your microphone. Also, some companies only allow certain accessories like a battery to be provided by them or special partner companies. So, please verify with your manufacturer that duracell batteries are allowed to be used within their products. Thank you.
11/17/2022 9:24:19 AM • Shure Audio... • Answered on Nov 17, 2022
How do I DISMANTLE SHURE KSM8 MIC
I used to send them to Shure for service or repair. https://www.google.com/search?q=DISMANTLE+SHURE+KSM8 ..
10/3/2022 11:00:08 PM • Shure Audio... • Answered on Oct 03, 2022
Really loud hum when recording through audio interface. How to fix it ?
It sounds like system incompatibility and the fact you are using a fake copy of one of the best microphones that has set an industry standard. See if you can find someone with a real Sure, or comparable mic. Also check the wiring and shielding on the mic, and also on the on the socket of the Complete. Hum and Buzz is nearly always bad wiring. You could also post here in this forum.
Komplete Audio 6 Mk1 vs Mk2 ' NI Community Forum - Native ...
https://www.native-instruments.com > forum > threads Jul 3, 2021 - Hi all I have a Komplete Audio 6 Mk1 audio interface, and I'm considering either upgrading to Komplete Audio 6 Mk2 or Komplete Audio 2 Mk2. https://www.google.com/search?q=komplete+audio+6+mk1+hum+on+microphone ..
2/10/2022 12:20:21 PM • Shure Audio... • Answered on Feb 10, 2022
Shure (LX287CC) Professional Microphone Logo
20 questions posted
Top Shure Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Cairns
Mike Cairns
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Shure Audio Players & Recorders
Most Popular Question
57abeta radio mic everything appears
  • Audio Players & Recorders
