20 Most Recent
Power Acoustik LT-980/2 Car Audio Amplifier Questions & Answers
The amp is in protect
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
A thumbs up would be greatly appreciated if this answer is helpful to you
How do i fix my
.A thumbs up would be greatly appreciated if this answer is helpful to you
Amp isn't putting out any sound
I have a Digital Audio model-DA2200W, Was listening to my tunes loud as always....then the subs quit bumpin...checked the subs cuz i thought i blew em...theyre fine...The power on the amp is still on...green light and all..just no output..I opened it up to see if anything looked burnt looks fine...is it toast or can i fix it??
How do i find how
According to
a listing on epinions, it appears that the amp is 8 ohms per channel standard, and can be bridged to 4ohms.
One post says that he has it bridged to 4 ohms and is getting 560 watts of output.
I couldn't find a manual for it, so you may want to contact Power Acoustik to be sure.
Ok so ive had this amp for about a year now and
I find that most Amps that does this the transistors nearest the to the B+ side of the Amp is bad. there are anywhere from 4 to 6 a side and if you know anything of these you can check them remove and replace them. I have a different problem. the prower light comes on and the goes off and I am trying to find a schematic to trace down the problem. if I find it I can talk U through it and show pics.
J, Todd
[email protected]
LT-980/2 Car Audio Amplifier: Looking to see if I can hardwire a Power Acoustik ...
you want to use a car amplfier indoors in the house
yeah that can be done very easily
just wire it like you would inside a car but you need to purchase a 12v DC adapter
i would go for one with at least 3A output (the bigger the better it depends on how much u wanna spend) from personal expericance 1.5A works but when it gets loud the amp stops and restarts
I have a rockfored fozgate 400w amp it was
Look for popped Capacitors. These are the tiny cans that are on the circuit board. They usually buldge out on the top and leak white paste.
Good luck and i hope this helps.
