20 Most Recent
Franke Saphira Espresso & Coffee Maker Questions & Answers
Malfunction 8 On Screen
Likely cause of this is a blocked worm drive. The worm drive takes the coffee in and then, after brewing, ejects the used grounds into the Dump box. Over time, coffee grounds accumulate on the worm drive and eventually jam it. This is Malfunction 8. Machine will need to be stripped and cleaned. Hope this helps.
I have a franke flair coffee machine when you
DESCALING
The Saphira has an integrated descaling program. The procedure takes about 60 minutes.
Once started, the descaling procedure may not be stopped.
• When acid-containing descalers are used, immediately remove any splashes or drops on
sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety
precautions.
• Turn off the Saphira by pressing the "ON/OFF" button.
• Press the button "Descale" until an acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: INSERT AGENT
IN TANK
• Display: PRESS
DECALCIFYING
Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty
water tank.
Place a sufficiently large container under the steam tube and the coffee delivery outlet.
• Press the Descale button
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• An acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: FILL
WATER TANK
• Display: PRESS
DECALCIFYING
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• Display: EMPTY
DRIP TRAY
• Display: CLEAN
CONTACTS
Good Luck
[email protected]
Machine grinds beans but dumps coffee in box cup
hi , sounds like the dump valve solenoid has failed or the valve on the base of the brewer has failed probably stuck,.which is the more likely culprit. let me know if you require more in depth help.
its not a problem that can be resolved by a novice.
If you need a Franke trained coffee machine engineer
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
How do I check the milk brother valve on my coffee machine
saphira? check the air nozzle on top of the cappu-outlet . if the machine indicates that you should descale, the cleaning cyclus wont work. to descale you have to turn off the machine by pressing the on-off button on the front side (behind the tea-and steam button). if the machine is turned off, press the descale button for 3 seconds. after the descaling cyclus you will be able to clean the machine.
Ho do I descale the machine
you need to shut down the machine on the frontpanel first. then you must push the descale-button (the one with the little triangles on it). the machine will give the instructions on the display. note that you have to use exactly 0,7 L of descaling product. the same for the rinsing water. if you use more, it will take a very long time ;-)
Drawer missing
Check that the pin on the drawer cover is not broken.This pin will activate the micro switch that tells drawer is in place.
