20 Most Recent MGI Software PhotoSuite SE V4.0 Questions & Answers
Yellow doesn't work on HP Deskjet 810C bubble jet printer
Try cleaning the contacts where the cartridge sits, a cotton bud or some lint free cloth with denatured alcohol or methylated spirit can clean a dirty contact.
12/5/2017 3:49:00 AM • MGI Software... • Answered on Dec 05, 2017
Ibp2900b canon printer www
Get the respective drivers from the website Canon.com, if they're not available, ask for their support.
6/8/2013 5:00:11 AM • MGI Software... • Answered on Jun 08, 2013
I use MGI photosuite and love it. I just bought a
Windows 7 and 8 much the same (32 and 64 bit) you may missing files for Internet Explorer.Just today I was able to get PhotoSuite 4 to work in Windows 8. PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD hasI.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway. I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running. Good luck!
3/6/2013 3:24:32 AM • MGI Software... • Answered on Mar 06, 2013
I need free mgi photosuite
If you have the original CD's then follow next: Just today I was able to get PhotoSuite 4 to work in Windows 8. PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD hasI.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway. I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running. P.S. 4 worked in windows 7 (update), not full install for me so I assume original I.E 5 files were replaced full install windows 8. Good luck!
3/6/2013 3:16:44 AM • MGI Software... • Answered on Mar 06, 2013
OLd Program 64bit windows 7
3/6/2013 3:11:44 AM • MGI Software... • Answered on Mar 06, 2013
I need to get MGI
Just today I was able to get PhotoSuite 4 to work in Windows 8 (64 BIT). PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD hasI.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway. I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running. Good luck!
3/6/2013 2:52:00 AM • MGI Software... • Answered on Mar 06, 2013
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)I hope this helps. Cindy Wells
3/25/2012 9:17:22 PM • MGI Software... • Answered on Mar 25, 2012
Where can i get a download for mgi photo suite for
torrent sites
6/25/2010 7:22:46 PM • MGI Software... • Answered on Jun 25, 2010
2answers
Need to get scanned photos to between 300 and 600 dpi
What I saw first off is that although the resolution indicates 96 DPI, the file size itself between the 2 examples are drastically different. You are putting raster images into MS Word for publication work, and that is a NO NO. Word was not created for any kind of high resolution printing. It's a glorified text editor that people seem to think is an option for printing. YOU WILL NEVER GET 300 or 600 DPI images out of Word. Ever.
To create your project for printing, you need to use software more suited for the task. InDesign and Quark are examples, but they are very expensive. In my opinion, Publisher would be better for this kind of project and I hate myself for saying that.
Talk to your Printer, find out his specifications for Applications and Linescreen for Printing. The minimum requirement is 280 DPI, but if the image is placed at 100%, 600 DPI is overkill.
Oh, and try to never scan a scan... you are looking for trouble... a little thing called a Moiré pattern comes into play, and it will make you images print NASTY!
I could go on about your post all day long, but if there is anything else I didn't explain, please post again.
6/5/2009 8:21:06 PM • MGI Software... • Answered on Jun 05, 2009
0answers
Will not load
Be the first to answer 3/16/2009 1:01:48 AM • MGI Software... • Posted on Mar 16, 2009Be the first to answer
2answers
I'm trying to send 600 photos that I have in a
No. Try uploading it to a site. A free one I use is http://www.adrive.com/ . The problem with sites like KodakGallery.com and others is that you can't give the entire photo to friends. Emailing is dangerous over 2-3 megs because if your friends have dial up, you have just clogged up their e-mail and then only their server can make their e-mail work again by going in to delete the clog.
2/20/2009 12:05:56 AM • MGI Software... • Answered on Feb 20, 2009
2answers
What exactly is Continuing professional development?
The continuing professional development or the continuing professional education is a method on how to maintain the knowledge and skills of participants in relation to the course you have finished and the line of work you are in. Enroll at online CPDs to learn the following towards increasing your level of knowledge and skill as well as expertise in your line of work. 1) Accreditation 2) Family Law 3) Criminal Law 4) Prison Law 5) Children Law 6) State Services for Older People 7) Conveyance 8) Wills & Probate 9) Landlord & Tenant 10) Employment Law 11) PI & Civil Litigation 12) Immigration 13) Regulatory & Mandatory 14) Membership.
4/16/2024 12:47:50 PM • Computers &... • Answered 2 hours ago
3answers
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 6:42:28 AM • Computers &... • Answered 8 hours ago
Do u guys know some good custom web app development services?
As far as I know, Digiteum is one of the best custom web app development services https://www.digiteum.com/web-application-development-services/. They offer comprehensive solutions tailored to clients' needs, with expertise in building innovative and scalable web applications. You might want to check them out for your project.
4/15/2024 11:23:03 AM • Computers &... • Answered Yesterday
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/15/2024 4:17:35 AM • Computers &... • Answered Yesterday
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered 2 days ago
MGI Software PhotoSuite SE V4.0 Logo
17 questions posted
Top MGI Software Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MGI Software Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MGI Software Computers & Internet
Most Popular Question
old program 64bit windows 7
  • Computers & Internet
