Hi
From the JennAir website:
Ceramic glass (on some models) IMPORTANT: Before cleaning, make sure all controls are off and the oven and cooktop are cool. Always follow label instructions on cleaning products. Soap, water and a soft cloth or sponge are suggested first unless otherwise noted.
Cleaning method: Always wipe with a clean, wet cloth or sponge, and then thoroughly dry the ceramic glass to avoid streaking and staining.
Cooktop cleaning and protectant aids
Cooktop Cleaner Part No. 31464 is recommended for regular use to condition the cooktop to help avoid scratches, pitting and abrasions.
Cooktop Scraper Part No. WA906B is also recommended for stubborn soils.
NOTE: The Cooktop Scraper uses razor blades. Store razor blades out of the reach of children.
These items and other accessories can be purchased by calling the Jenn-Air Customer eXperience Center at: 1-800-536-6247.
Light to moderate soil
Paper towels or clean, damp sponge.
Sugary spills (jellies, candy, syrup)
Use the Cooktop Scraper.
- Clean while the cooktop is still warm.
- You may want to wear oven mitts while cleaning the cooktop.
Use the Cooktop Polishing Creme and a clean, damp paper towel.
- Clean as soon as cooktop has cooled.
- Rub creme into surface with a damp paper towel or soft cloth.
- Continue rubbing until white film disappears.
Heavy soil, dark streaks, specks, and discoloration
Use the Cooktop Polishing Creme or a nonabrasive cleanser.
- Rub product into soil with a damp paper towel or soft cloth.
Burned-on soil
Use the Cooktop Cleaner and Cooktop Scraper.
- Rub creme into soil with damp paper towel.
- Hold scraper as flat as possible on surface and scrape.
- Repeat for stubborn spots.
- Polish entire cooktop with creme and paper towel.
Metal marks from aluminum and copper
Use the Cooktop Cleaner.
NOTE: The marks will not totally disappear, but after many cleanings they will become less noticeable.
Tiny scratches and abrasions
- Scratches and abrasions do not affect cooking performance, and after many cleanings they will become less noticeable.
IMPORTANT: To avoid damage to the cooktop, do not use steel wool, abrasive powder cleansers, chlorine bleach, rust remover or ammonia.
To Self-Clean:
- Close the oven door.
- Press Clean. “Clean,” “Set,” and “Upper” or “Lower” will flash in the display.
- Press Autoset. MEd (Medium soil, 3 hours) appears in the display.
NOTE: If the door is not closed, oven will beep and “door” will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 30 seconds, the self-cleaning operation will be canceled and the display will return to the time of day.
To choose a clean setting other than Medium, press Autoset to scroll through the self-cleaning settings.
HVy (heavy soil, 4 hours)
MEd (medium soil, 3 hours)
LITE (light soil, 2 hours)
Choosing the soil level of the oven automatically programs the self-cleaning time.
- After 4 seconds, the oven will start cleaning. “Clean” will appear in the display. “Lock” will flash in the display. Once both the oven doors lock, “Lock” will remain lit. The cleaning time will count down in the display.
When the Self-Clean cycle ends:
“Lock” will turn off approximately 1 hour after the end of the clean cycle. The door can then be opened.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
